Consider the situation where I have a set of Fortran 77 subroutines with one driver subroutine that represents a numerical method. These subroutines have many common blocks that share data and variables between them. I would like to make the common block information thread-safe. Is that possible with the following procedure:
(1) create a module subprogram in F90 but in a fixed source format file (*.for).
(2) paste the F77 subroutines in the module in the "contains" section.
(3) declare all the subroutines to be private
(4) write a public wrapper subroutine within the module that calls the driver.
An explanatory code is below (the calculations are only an example):
MODULE THREAD_SAFE_FUNCTION
PRIVATE
TYPE, PUBLIC :: MYVAR
INTEGER :: N
REAL :: S
REAL, DIMENSION(:), ALLOCATABLE :: P
CONTAINS
PROCEDURE, PASS(SELF) :: DRIVER
END TYPE MYVAR
CONTAINS
SUBROUTINE DRIVER(SELF,N,Y,S)
CLASS(MYVAR) :: SELF
INTEGER :: N
REAL :: S,Y(N)
SELF%N = N
ALLOCATE(SELF%P(N))
SELF%P = Y
CALL TASK1(N,SELF%P,S)
SELF%P=SELF%P**2
END SUBROUTINE DRIVER
SUBROUTINE TASK1(N,Y,S)
COMMON /COM1/A,B,C ! WANT COM1 AND COM2 TO BE THREAD-SAFE
COMMON /COM2/Z(10)
INTEGER N
REAL S,Y(N)
INTEGER I
A=1
B=2
C=3
DO I=1,N
Z(I)=I
ENDDO
CALL TASK2(N,Y,S)
RETURN
END
SUBROUTINE TASK2(N,X,S)
COMMON /COM1/A,B,C
COMMON /COM2/Z(10)
INTEGER N
REAL S,X(N,3)
INTEGER I
C SOME CALCULATIONS HERE
A=2*A
S=0.0D0
DO I=1,N
S=S+Z(I)**2
ENDDO
S=SQRT(S)
RETURN
END
END MODULE THREAD_SAFE_FUNCTION
When I invoke a search engine for the phrase "openmp common threadprivate" I get several excellent online references. You may note that ifort has been more picky than most about where the common /threadprivate is placed and assuring that all instances of the COMMON match lengths..
There is no difference in facilities between fixed and free form - so your point (1) can be answered with "yes".
That said, modules are not about thread-safety and COMMON block simply cannot be made thread-safe.
But do not despair: you can use internal routines for the job, but in a slightly different way than you proposed:
! Driver routine calls the "master" routine
call calculate_via_driver( ..., master_routine )
! master routine
subroutine master_routine( ... )
implicit none
integer :: x, y, z ! Originally defined in COMMON-block
real :: a, b, c
... preparations ...
call step1
call step2
contains
subroutine step1
a = x + y ! These are all defined in the master routine
end subroutine step1
subroutine step2
b = 2.0 * a
end subroutine step2
end subroutine master_routine
The variables x, y, z, a, b, c are defined locally in the subroutine master_routine - you could have one instantiation in one thread and another in another thread and the actual memory locations for these variables would be completely independent, hence thread-safe.
The drawback of converting the COMMON blocks into local variables in an overall "master" routine is that they do not retain their values between calls. You can not use the SAVE attribute, because that would destroy the "localness". If you want to retain the values, use a derived type like you indicated:
- Store these variables in this derived type (or object)
- Copy their values into local variables at the start
- Do the calculations
- Copy the new values back in
- Pass the derived type to the master routine as a dummy/actual argument - one actual, unique, argument for each thread
No time right now to provide a working example, but I hope the method is clear enough.
Hm, I forgot about that clause in OpenMP ... If you do use that method, it might be your simplest option.
Common has been used for many decades in multithreaded and multiprocessor asynchronous parallel applications. A typical method was to include a command/response communication interface. So, no access was made until assigned the use of the area. Once assigned, a thread or processor defined the content as required and then set a command or status response (bit) as appropriate to the operation performed and identified the operation expected by the recipient as required. A simple handshaking approach is really pretty fast and only typically needed for a subset of communications that really need to be shared. This also worked well for data capture, where a parallel processor filled a transfer buffer(s) while a second processor dumped the buffer(s) to a recording medium, preventing one getting ahead of the other or reusing a buffer that was in use or yet to be processed.
So, common can work fine in a multithreaded environment with a tiny little bit of thought. No, it won't happen naturally/natively. But it can generally happen with far less overhead than many message passing schemes.
P.S. I guess I should clarify that I wasn't intending to advocate the use of common as a mechanism for setting up a shared memory area. Only that the dangers of fixed shared memory buffers as a design approach are often vastly overstated.
Thanks for the useful responses. Hence, it appears that common statements in subroutines within modules are not guaranteed to be thread-safe although in practice they may work fine in a multithreaded environment. Using local variables with module scope as suggested is an alternative. However, (a) I want to avoid modifying code unless absolutely necessary and (2) in some cases, the common block variables do not have the same name i.e. /COM1/a,b,c in one subroutine and /COM1/x,y,z in another subroutine, which again makes modification complicated when you are working with legacy code.
I have seen worse problems with COMMON in old codes. Not only the names but even the types of the variables can be different in multiple declarations of COMMON in multiple subprograms. Sometimes, a common block variable has been initialized more than once using DATA statements. These kinds of lax usages can be quite troublesome even in a single-threaded program.
Try:
! threadprivate_COM.inc COMMON /COM1/ A, B, C !$OMP THREADPRIVATE( /COM1/) REAL :: A, B, C COMMON /COM2/ Z(10) !$OMP THREADPRIVATE( /COM2/) REAL :: Z ! end of file threadprivate_COM.inc ============================ new file ==== SUBROUTINE TASK1(N,Y,S) ! *** replace all instances COM1 and COM2 in all other files *** INCLUDE 'threadprivate_COM.inc' ...
*** CAUTION ***
In older programs, quite often, a common block, say COM2 array Z, will get re-mapped with scalars or use differing names. You will have to sort this out using different files.
Also, assure that no global variables (visible to all threads) are included in the newly created thread private commons.
Jim Dempsey
Additionally,
I would (strongly) suggest replacing the COMMON blocks with data collections in MODULES. Modules can also have threadprivate entities. Note, you may still have issues of name conflicts, as well as data placement conflicts, should your same named common blocks have different mappings and/or types.
The most important first step is to insert IMPLICIT NONE in all procedures, and build your single threaded version, correct for undefined variables. When build succeeds, verify consistent results data, if not, correct.
Then migrate COMMONs to MODULEs, one file per named common, my preference is to pre-pend to the old common block name "mod_", e.g. mod_COM1 for COMMON /COM1/.
In the case where the former named common maps different names and/or types, a technique that can be used is to create a user defined type. Example:
! mod_COM1.F90
type COM1_t
sequence
union
map
real :: x, y, z
end map
map
real :: alpha, beta, gamma
end map
end union
end type COM1_t
type(COM1_t) :: COM1
!$OMP THREADPRIVATE(COM1)
SUBROUTINE TASK1(N, Y, S)
USE mod_COM1
IMPLICIT NONE
INTEGER :: N
REAL :: Y, S
COM1%A = 1 ! was A=1
CALL TASK2(N, Y, S)
CALL OTHER_SUB
SUBROUTINE TASK2(N, Y, S)
USE mod_COM1
IMPLICIT NONE
INTEGER :: N
REAL :: Y, S
SUBROUTINE OTHER_SUB
USE mod_COM1
IMPLICIT NONE
COM1%alpha = 1 ! was alpha = 1
Now, expect a lot of flack
"Warning Will Robinson - unions are bad"
Jim Dempsey
