!DEC$ ADDRIBUTES Help
garylscott1
I need to write an interface for the below C function. I'm not sure how to declare the interrupt handler
!_EXTERN S16BIT _DECL aceSetIrqConditions( S16BIT DevNum,
! U16BIT bEnable,
! U32BIT dwIrqMask,
! void(_DECL *funcExternalIsr)(S16BIT DevNum, U32BIT dwIrqStatus));
! My attempt
interface
use EMACEKinds, only : S16BIT, U16BIT, U32BIT
integer(S16BIT) function aceSetIrqConditions(DevNum,bEnable,dwIrqMask,funcExternalIsr)
!DEC$ ATTRIBUTES C,ALIAS:"__aceSetIrqConditions" :: aceSetIrqConditions
!DEC$ ATTRIBUTES VALUE :: DevNum
!DEC$ ATTRIBUTES VALUE :: bEnable
!DEC$ ATTRIBUTES VALUE :: dwIrqMask
!DEC$ ATTRIBUTES REFERENCE :: funcExternalIsr !function pointer to interrupt service routine
integer(S16BIT), intent(in) :: DevNum
integer(U16BIT), intent(in) :: bEnable
integer(U16BIT), intent(in) :: dwIrqMask
integer(U16BIT), intent(in) :: funcExternalIsr
end function
end interface
! Interrupt Service Routine ??
interface
use EMACEKinds, only : S16BIT, U32BIT
integer(S16BIT) function funcExternalIsr(DevNum,dwIrqStatus)
!I don't think I should use following C attribute, isn't this an internal fortran routine?
!DEC$ ATTRIBUTES C,ALIAS:"__funcExternalIsr" :: funcExternalIsr
!DEC$ ATTRIBUTES VALUE :: dwIrqStatus
integer(U16BIT), intent(in) :: dwIrqStatus
end function
end interface
garylscott1
or attributes rather
