29348 Discussions
DLL cannot be loaded on other machine
rinkeke
I compiled a dll with the FORTRAN 11 compiler under visual studio 2005, using the IMSL 6 libraries which I linked statically. It compiles and the program works fine on my computer. However, on my other computer, on which VS 2005 and IMSL 6 are not installed, I get an error message that the dll cannot be loaded. Previously, I used MS Visual studio .net 2003, FORTRAN 8 and IMSL 5 and under that configuration a compiled dll worked fine on other machines. I've checked all the includes, library settings etc, but cannot find the cause of this problem. Any suggestions are very welcome.
Thanks, Rinke
Standard advice - run Dependency Walker on the DLL to see what it depends on. Even if you're using the static IMSL, you'll be linked against the DLL form of the OpenMP run-time, libiomp5md.dll.
rinkeke
Hi Steve,
Thanks, I ran DW and indeed I found that the link to libiomp5md.dll is missing. Do you know any way to get around that? I tried to put it in the additional dependencies list, but that gives fatal errors because of reading rights.
Rinke
rinkeke
rinkeke
Thanks ! You make my day
