29565 Discussions
DLL generation and static linking to intel runtime libraries
DataScientist
Valued Contributor I
What is the required flag to generate DLL with the intel runtime libraries linked statically to the DLL? I guess this is in general not a good idea. But in cases where the DLL is going to be used from other languages such as MATLAB/Python/R, it can be quite helpful since there would be no need for a separate installation of the runtime libraries. On Linux, -static-intel achieves the goal, but on Windows, I am not sure what flag is needed. Thanks for any suggestions.
Steve_Lionel
/MT or /libs:static /threads. In Visual Studio, select "Multithreaded" when building the DLL.
Steve_Lionel
DataScientist
Steve, Thank you. Does it also automatically link the static Intel MPI library? I suppose it does not.
Steve_Lionel
If you want MPI you have to specify it yourself. The only time the compiler will link in MPI is if you enable coarrays and then it's always the shared library. (There is no static coarray support library.)
