Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
For the latest information on Intel’s response to the Log4j/Log4Shell vulnerability, please see Intel-SA-00646
26861 Discussions
DPD200247916 (debug reformat display type) followup
Cunningham__Matt
Hi
I saw an old post (earlier this year) that referenced an existing problem, DPD200247916.  This relates to not being able to use the debugger (i.e., VS2015) with Intel Fortran XE2016 to view variables in alternative formats - for example REAL*8 MyVar displayed in debugger as string using MyVar,s.
First is there an update on this, is it working again and if so which update has the fix?
Second, can I do this with arrays as well?  So similar to the above example, can I have REAL*8 MyVar(100) and can I show all array contents as strings?
Steven_L_Intel1
This was fixed in, I think, Parallel Studio XE 2016 Update 3.
