29419 Discussions
DPD200256205 Have -warn unused warn about unused ONLY names
andrew_4619
I recall discussing this in a thread somewhere but I can't seem to find it, Anyway this document
https://software.intel.com/en-us/node/520142
Suggests "DPD200256205 Have -warn unused warn about unused ONLY names"  is in the new release. I took this to mean that:
USE FRED, ONLY: bill, alan, peter
would throw a warning if for example alan was not used in the scope of the USE. I was quite looking forward to this feature, did it fall off the list at some point or have I misunderstood?
FortranFan
I'm looking forward to this feature too and my expectation is also along the lines mentioned by app4619 in the original post.
But I didn't notice such a feature in the 2015 Beta version, so it'll be surprising if it is available in the final release.
Lorri_M_Intel
This was added late in the Beta cycle, and should be in the final product
Are you guys seeing something different?
           --Lorri
andrew_4619
           --Lorri
I do not seem to be seeing that feature. I was expecting to have quite a number of warnings and when I didn't I deliberately created some lines that should have given a warning. Try a simple test case.
Lorri_M_Intel
Hmm.   Our regression test looks like this:
module cq256205mymod
integer a, b, c, x
end module cq256205mymod
program cq256205
use cq256205mymod, only: a,b,c
integer d
a = 1
b = 2
print *, "success"
end program
and does issue two warnings when compiled as:
ifort /warn:unused cq256205.f90
One message for "d"  one message for "c"
What is different about your example?
andrew_4619
Yes that example works for me also. The example I tried where in a large application with many modules etc. There are also different build options e.g. I only check the warning on debug builds. I will investigate further and report back.
andrew_4619
It does not warn when the "unused only" is within a module procedure it would seem. No warning for "c". As all my routines are usually within modules that appears to be why I get no warnings.
    implicit none
    integer a, b, c, x
module fred
    contains
    subroutine bill
        implicit none
        integer f
        a = 1
        b = 2
        print *, "success"
    end subroutine bill
end module fred
program cq256205
    use fred
    implicit none
    integer d
    a = 1
    b = 2
    print *, "success"
    call bill()
end program
1>------ Build started: Project: Console3, Configuration: Debug Win32 ------
1>Compiling with Intel(R) Visual Fortran Compiler XE 15.0.0.108 [IA-32]...
1>Console3.f90
1>C:\Users\Andrew\Documents\Cadfil\cadfil_devt_intel\Console3\Console3.f90(11): remark #7712: This variable has not been used.
1>C:\Users\Andrew\Documents\Cadfil\cadfil_devt_intel\Console3\Console3.f90(22): remark #7712: This variable has not been used.
Lorri_M_Intel
Thank you for the investigation --- I'll send that info over the wall to my colleague.
FortranFan
app4619 wrote:
.. As all my routines are usually within modules that appears to be why I get no warnings...
Same situation with me; almost all the code is in modules.
andrew_4619
Was there any feedback on this issue ?
Andrew
Lorri_M_Intel
Hi Andrew --
      He acknowledged that it failed, but there's no schedule for the fix yet.
I was just informed that the fix for this problem is expected to be in Update 1.
andrew_4619
Thanks that will be most welcome :-)
andrew_4619
And indeed is seems to be working in update 1!
I was pleasantly surprised and the relatively small number of warnings I got when doing a full rebuild of a large project :-)
it is nice to have some spring cleaning in your code even if it is winter.
DavidWhite
Valued Contributor II
Depends where you are ... it's still Spring here until Monday :-)
It's technically not winter here for another few weeks, but we did just have our first snow of the season in southern New Hampshire.
JVanB
Sounds like the difference between meteorological and astronomical winter. A-basin opened last month, does that make it winter here?
andrew_4619
    implicit none
    integer :: a, b, c, x
module fred
    integer :: y,w
    contains
    subroutine bill
        use cq256205mymod, only: a,b,c !c unused remark #7712
        implicit none
        integer f                      !f unused remark #7712
        a = 1
        b = 2
        print *, "success"
    end subroutine bill
end module fred
program cq256205                       ! test for /warn:unused Fortran Compiler XE 15.0.1.148 [IA-32]
    use fred, only: y,bill             ! bill is NOT reported as unused
    implicit none
    integer d                          ! d unused remark #7712
    a = 1
    b = 2
    y = 1
    print *, "success"
    !call bill()
end program
I think I spoke too soon..... I noticed some issues with this feature yesterday and have updated the test that was at #7. The problem is the line
use fred, only: y,bill as it seems that unused applies to variablies and not module procedures.  Perhaps that was the intention?
FortranFan
Yes, it'll be nice if /warn:unused applies to module procedures too.
Well, the option's documentation does say: "Determines whether warnings occur for declared variables that are never used." A procedure is not a variable. Nor is a type or an interface. I will enter a feature request that any identifier in a USE list qualify for the warning. Issue ID is DPD200365039.
FortranFan
See recent discussion at comp.lang.fortran: https://groups.google.com/forum/#!topic/comp.lang.fortran/RedeUCqh12c
I think the warning in this case is unwaranted: thoughts?
