Debugging inside a BLOCK construct
Andrew_Smith
Valued Contributor I
With IFORT (Intel® Fortran Compiler Classic 2021.12.0 [Intel(R) 64]) the variables declared local to the block cannot be seen by the debugger.
So I switched to IFX (Intel® Fortran Compiler 2025.2.1 [Intel(R) 64]) and now they can be seen. But the local variables declared outside the block are now invisible!
Attached files replicate the problem with IFX. The use of an include file triggers the issue.
jimdempseyatthecove
You win some - you lose some.
As a hack
block
associate(VariableOfInterest_=>VariableOfInterest)
real :: blockLocalVariable
end associate
end block
Jim Dempsey
JohnNichols
Honored Contributor I
Jim:
Why would you use a block?
It is like starting a fire with a match when someone has a torch.
JMN
andrew_4619
You would use one because they can be quite useful and they exist!
jimdempseyatthecove
Think of a BLOCK as an inline contained subroutine complete with its own local variable declarations yet within the scope of the procedure containing the block.
Jim Dempsey
Andrew_Smith
The c language and most others allow variables to be declared when needed anywhere within your statements.
Fortran restricts us to declare all variables before any statements. I am not sure why Fortran has always had this restriction. Has there been proposals to change the standard in this area? I cant imagine it would affect performance but would greatly improve the coding experience.
A Fortran BLOCK allows you to create new variables almost anywhere. Its not as nice or as flexible as c.
JohnNichols
Accepting all that is said, I like a nice subroutine name such as
INPUT
LOAD
ANALYSIS
EIGENVALUES
OUTPUT
