29648 Discussions
Defining structure elements using DATA statements
Intel_C_Intel
I defined a somewhat complicated structure and I use DATA statements to define each element of the structure. I am having a strange problem, as follows:
If I use a statement of the form
DATA EXPERT(1)%FREQ(2)%SIG%b1 / 0.278 /
it compiles properly and the debugger indicates that the values are being defined properly.
On the other hand, if I use "." instead of "%" in the data statement (which should be equvalent), I get the following errors:
Error: Syntax error, found '.' when expecting one of: ( :: , ; ) % . / = =>
DATA EXPERT(1).FREQ(2).SIG.b1 / 0.278 /
Error: Syntax error, found END-OF-STATEMENT when expecting one of: ( ...
Is this a bug in the compiler, or am I doing anyhing wrong? Executable statements using the dot notation, and data statements for elements of the form EXPERT(1).FREQ(2).CASE(1).c1, seem to work OK. BTW, I am using CVF 6.6A
Gabriel
Probably a bug - we've had similar issues in the past. Please report it to [email protected]
Steve
