29376 Discussions
Dependency problem in VS2003 after installing IVF 10
longden_loo
I bit the bullet and got IVF 10.0-027, and installed it over VS2003 [ .NET framework 1.1.4322 SP1 ].
Now when I try to set project dependencies, VS won't let me toggle the checkboxes in front of the project names. On an existing solution, I can't uncheck a dependency, nor check a new one. On creating an empty solution and adding 2 empty console application projects, I can call up the project dependencies dialog and one project is listed with an empty checkbox which I can't toggle on.
Is this a known bug in the Fortran Integrations for VS? I was pretty sure the IVF 10 software requirements showed it's supposed to work with VS 2003 ... or was I wrong?
- Longden
VS2003 is supported and I use it with IVF 10 several times a week. I have not heard of this symptom before. Try uninstalling and reinstalling the integration. If that doesn't help, please describe the problem to Intel Premier Support.
longden_loo
I did as you suggested and the problem remained, so I uninstalled IVF again (completely) and VS 2003 still exhibited the problem using a generic solution and C# projects ... so I think I have an issue with my VS 2003 environment. I don't have the time to reinstall VS 2003 right now so I'll work around the problem for the moment.
It's was still useful to note that this problem is probably an aberration in my setup.
cisteefel
Not sure this is really the same problem, but I was seeing that the Properties could not be reset inside of Microsoft Visual Studio .NET 2003 when used with the newly loaded IVF 10. I uninstalled and reinstalled IVF and this had no effect. I ended up uninstalling the Microsoft Visual Studio and IVF completely, then reinstalling and this fixed the problems.
So I would bite the bullet and uninstall completely the VS 2003...
longden_loo
Thanks, this is useful information to pass on to another coworker seeing the same problem (but with IVF 9.0, not IVF 10).
Fortunately I don't have that bullet to bite since the computer where I'm having the problem is slated for replacement this week. So my new computer will have a fresh installation of both VS 2003 and IVF 10 anyway.
- Longden
