Detect Windows or Qwin program
BearofLittleBrain1
I have two almost identical routines that differ by only one statement, depending on whether the program in which they run is Windows or Qwin.  Is it possible to detect which it is when executing?  Then I could combine the two routines with an IF statement and avoid confusion.
BearofLittleBrain
andrew_4619
Surely at compile time you know what the application type is anyway so you can set your own variable to differentiate?
BearofLittleBrain1
Andrew,
You are, of course, completely right.  I realised that is how to do it about a minute after pressing the "Post" button.
BearofLittleBrain
