29274 Discussions
Dialog Subclassing in 64 bit applications
dannycat
The following code is included in a dialog subclassing module I have used successfully in the 32-bit configuration of the application:
integer(HANDLE) :: hTabDlgProc(7)
!DEC$ IF DEFINED (WIN64)
hTabDlgProc(2) = SetWindowLongPtr(gdlg_tab2%hWnd, DWL_DLGPROC, LOC(Tab2DlgProc))
!DEC$ ELSE
hTabDlgProc(2) = SetWindowLong(gdlg_tab2%hWnd, DWL_DLGPROC, LOC(Tab2DlgProc))
!DEC$ ENDIF
The function referred to in the LOC() functionis defined as follows:
function Tab2DlgProc(hDlg, message, wParam, lParam)
!DEC$ ATTRIBUTES STDCALL :: Tab2DlgProc
use dfwin
implicit none
! Arguments
integer(SINT) :: Tab2DlgProc ! Declare the function
integer(HANDLE) :: hDlg ! Integer identifying the window handle of the dialog box
integer(UINT) :: message ! Integer identifying the window message
integer(fWPARAM) :: wParam ! message-specific information
integer(fLPARAM) :: lParam ! message-specific information
The SetWindowLong function returns a value in 32-bit version but returns zero in the64-bit versionwhere SetWindowLongPtr is required. Any ideas why this is? I suspect the function declaration:
integer(SINT) :: Tab2DlgPoc
If anyonecan help with this it will be most appreciated.
Jugoslav_Dujic
Valued Contributor II
Not that it is relevant to your current discussion, but I think you should ensure that you pass on messages that you do not process inside the IF block and move the 'end select' and include a CASE DEFAULT to pas on all other messages
No, his code structure is fine: there's a RETURN statement within CASE (WM_CTLCOLOR...), so it comes down to the same thing. Like you, Tony, I prefer the CASE DEFAULT, but he's fine as it is.
However, there are two other issues:
1) As I hinted above, try replacing DWL_DLGPROC with GWL_WNDPROC in the call to SetWindowLong(Ptr). I'm not sure how it ever worked in Win32, but it apparently does not in Win64.
2) You have a massive GDI leak -- every while you CreateSolidBrush, but never DeleteObject. Unfortunately, you need to go through some hoops to correctly create and delete the brushes, along the lines of:
[fortran]integer(HANDLE), save:: hPinkBrush = 0
case (WM_COLORSTATIC)
  !Create the brush only once, first time we enter here:
  if (hPinkBrush==0)
     hPinkBrush = CreateSolidBrush(...)
  Tab2DlgProc = hPinkBrush
case (WM_DESTROY)
  iret = DeleteObject(hBrush)
  iret = CallWindowProc(...)[/fortran]
I must say that the whole WM_CTLCOLOR* mechanism sucks, and it's probably a leftover from some GDI structure at Windows 3.1. They could have had WM_SETCOLOR (of which, IIRC, only PBM_SETCOLOR and another one exist), but we're apparently stuck with this...
IDZ_A_Intel
I'm confused by your description. You should use SetWindowLongPtr in both architectures. The return type of the dialog procedure does not matter (or rather, (SINT) is correct.)
dannycat
Steve,
In my original code, writtenfor CVF, I utilisedSetWindowLong() and this worked fine. When I tried SetWndowLongPtr() the code would not compile. When I moved over to IVF and tried to compile the 64-bit config I got a message relating to the SetWindowLong() function having mis-matched arguments, supporting your statement above. I kept the original function in so that the code would still compile with CVF and as it also works OKfor 32-bit IVF. Unfortunately when I run the 64-bit config, the debugger shows a zero return from SetWindowLongPtr(), presumably indicating a problem.
What other reason would this function fail?
IDZ_A_Intel
Call GetLastError() after the fail to see why it failed.
dannycat
It comes up with error 1415 "Using PRIVATE dialog window words". Why should this be different for 64-bit when it works in 32-bit, unless the function is looking at the wrong words in dialog structure.
Jugoslav_Dujic
Hm. As far as I know, you aren't supposed to change the dialog procedure (the thingo returned by DWL_DLGPROC) in run-time. You can change the window procedure (the thingo returned by GWL_WNDPROC). Maybe Win32 lets you do that, but -- I think correctly -- Win64 won't.
Well, not sure how it worked in win32 in the first place -- maybe it would for some simple cases. From your subclassing procedure, do you CallWindowProc or return true/false?
For an explanation of differences between dialog procedure and window procedure, see this recent post of mine.
dannycat
[fortran]Jugoslav, I use CallWindowProc as shown below.[/fortran]
[fortran][/fortran]
[fortran]function Tab2DlgProc(hDlg, message, wParam, lParam)
use dfwin
implicit none
! Arguments
! Local Variables
integer(HANDLE)  :: hWndControl
integer(HANDLE)  :: hDCControl
integer(HANDLE)  :: ret, hbkcolor
integer          :: j
! delete any existing brush created earlier
if(hTabBackbrush(2).ne.0) then
  ret = DeleteObject(hTabBackbrush(2))
endif
select case (message)
! Dialog box drawing message - create  PURPLE background
case (WM_CTLCOLOREDIT,WM_CTLCOLORSTATIC)
! Edit Control
  hdcControl  = wparam
  hwndControl = lparam
! Use hwndControl to identify the control
  do j = 1 , nCtrl
    if(hWndControl.eq.hCtr(j).and.cTyp(j).eq.message) then
	  hTabBackbrush(2) = CreateSolidBrush(RGB(int1(cBkRGB(j,1)),int1(cBkRGB(j,2)),int1(cBkRGB(j,3))))    ! Create a brush
	  hbkcolor   = MSFWIN$SetBKColor(hdcControl,RGB(int1(cBkRGB(j,1)),int1(cBkRGB(j,2)),int1(cBkRGB(j,3))))    ! Set the text background
	  Tab2DlgProc  = hTabBackbrush(2)    ! return the window background brush handle immediately
	  return
	endif
  enddo
end select
! pass all other messages on to the default window procedure
Tab2DlgProc = CallWindowProc(hTabDlgProc(2), hDlg, message, wParam, lParam)
return
end function Tab2DlgProc
[/fortran]
[fortran]Are you suggesting an alternative method?[/fortran]
anthonyrichards
New Contributor III
Not that it is relevant to your current discussion, but I think you should ensure that you pass on messages that you do not process inside the IF block and move the 'end select' and include a CASE DEFAULT to pas on all other messages, as follows
Do...
if...
else
! If neither of these control messages are processed inside this if block,
! pass them on to the default window procedure
end if...
end do
case default
end select
return
end function
dannycat
Thanks Anthony, although it worked OK before I'll amend my code accordingly. As you said it doesn't solve my 64-bit problem though.
Jugoslav_Dujic
  if (hPinkBrush==0)
case (WM_DESTROY)
dannycat
Juguslav,
Replacing DWL_DLGPROC with GWL_WNDPROC did the trick. With regard to the GDI memory leak I destroy the brush objects in the DLG_DESTROY segment of the dialog callback. The handles are stored globally within the module so that this can be done.
Steve (dannycat)
