EC.EXE
csmythe
I have been trying to use the utility EC.EXE to capture command-line error messages to a file. I'm having two difficulties:
first, EC crashes if the file pathnames in the command have any spaces. E.g.
EC "c:program filesexecutable.exe"
doesn't work.
Second, there seems to be a limit on the length of the command line EC can accept. It seems to work or not depending on the length of the pathnames. Is that correct?
Chuck Smythe
james1
Cannot help you with EC, but perhaps you can trap your error message by using command line redirection of standard error. Depends on your OS I believe.
James
I can reproduce the problem with the embedded spaces. I'll ask the engineer who wrote it why this is.
Steve
