Edit Boxes
timberwolf
An edit box on a dialog box, how would you make it visible or not visible on the dialog box?
For example:
if a check box is checked then the edit box is visible and if the check box is not checked then the edit box is not visible.
Any help is appreciated. Thanks.
Jugoslav_Dujic
Valued Contributor II
SUBROUTINE OnCheckBoxChange(Dlg,ID,iEvent)
USE DFWIN
iret = DlgGet(Dlg, IDC_CHECKBOX, bState)
IF (bState) THEN
iShow = SW_SHOW
ELSE
iShow = SW_HIDE
END IF
iret = ShowWindow(GetDlgItem(Dlg%hWnd, IDC_EDITBOX), iShow)
Also, take a look at XFLOGM extension on my home page -- it has DLG_VISIBLE control index as an extentsion.
(See also this recent reply of mine -- there are issues if you need it at dialog startup).
Jugoslav
