29648 Discussions
Elemental subroutine causes pointer bad mapping when source allocation is used
kostas85
Hello again,
The following code is somewhat of an extension of my previous post. As before we define two derived type t1, t2 and three function. A function that produces as output an array of t2 and two function, an elemental and a classic one, whose output is a real. When source allocation is used to store the result of the elemental function producing the real, a pointer is erroneously mapped to the result. The mapping is correct when classic allocation is used. The code also behaves correctly independently of source/classic allocation when type t2 is defined by only one integer. The code follows along with correct/wrong results. This behavior is observed for both previous and current version. Please let me know if this is related to previous post regarding class/elemental subroutine. Since I was not sure I decided to create a different post. Thank you!
module type_funs
type t1
  integer :: i
end type t1
type t2
  integer :: i
  ! commenting the integer below makes source
  ! allocations to work properly
  integer :: j=0
end type t2
type(t1) :: t1_start = t1(0)
 contains
real elemental function uni_op(this) result(res)
type(t2), intent(in) :: this
res = this%i**2
end function uni_op
function uni_op_arr(this) result(res)
type(t2), intent(in),dimension(:) :: this
real, dimension(size(this)) :: res
res = this%i**2
end function uni_op_arr
function bin_op_arr(this,that) result(res)
type(t1), dimension(:), intent(in) :: this
type(t1), intent(in) :: that
type(t2), dimension(size(this)) :: res
res%i=this%i-that%i
end function bin_op_arr
end module type_funs
program test_funs
use type_funs
implicit none
! this produces wrong results
type(t1), dimension(:), allocatable :: t1arr
real,dimension(:), allocatable,target :: values
real,dimension(:), pointer :: pvalues
allocate(t1arr(10))
t1arr%i=[1:10]
! commenting source allocation and uncommenting the "classic" one
! gives always correct results for the elemental function gives the
! correct result, the result is always correct when uni_op_arr is used
allocate(values, source=uni_op(bin_op_arr(t1arr,t1_start)))
!allocate(values, source=uni_op_arr(bin_op_arr(t1arr,t1_start)))
!allocate(values(10))
!values = uni_op(bin_op_arr(t1arr,t1_start))
print *, values
pvalues => values
print *, pvalues
end program test_funs
Wrong Result
  1.000000       4.000000       9.000000       16.00000       25.00000
   36.00000       49.00000       64.00000       81.00000       100.0000
   1.000000       9.000000       25.00000       49.00000       81.00000
  0.0000000E+00  0.0000000E+00  0.0000000E+00  0.0000000E+00  0.0000000E+00
Correct Result
Kevin_D_Intel
For this case, I found the correct results are produced with the final 13.1 release, Version 13.1.3.192 Build 20130607, and the incorrect results occur with the initial 14.0 release, Version 14.0.0.080 Build 20130728.
I will investigate further and post another update shortly.
kostas85
I am not keeping track of versions older than the previous. So I am compiling with Version 14.0.3.174 Build 20140422 and the last. Thanks a lot for your interest.
Kevin_D_Intel
Thank you for the note about your ifort version. I confirmed the reproducer produces the unexpected mappings with both the 14.0 and 15.0 compilers and expected mappings for each work around you noted. I submitted this to Development (see internal tracking id below) as a separate defect from your earlier related post and will keep you updated on the status as I learn it.
(Internal tracking id: DPD200362026)
(Resolution Update on 11/26/2015): This defect is fixed in the Intel® Parallel Studio XE 2016 Update 1 Release (PSXE 2016.1.056 / CnL 2016.1.150 - Linux)
Kevin_D_Intel
I confirmed this issue is fixed in our upcoming Parallel Studio XE 2016 Update 1 release which should be available soon.
