29276 Discussions
Error #8346: A function reference cannot be used as the leftmost part-ref of structure component.
S__MPay
I have made a class named shape which has an array field from class segment. Also there is a class vector.
So I can use my_element%segments(1)%make_vector() to return a vector object.
So far so good by if I use:
print*, my_shape%segments(1)%make_vector().length()
I will get this error
To me that statement makes sense so, why compiler is not happy?
FortranFan
You will have to do something along the following lines to get it to work:
   asc: associate( vector => my_shape%segments(1)%make_vector() )
      print*, vector%length()
   end associate asc
where the returned object from the make_vector function is "pointed" to something within the ASSOCIATE construct which allows referencing of members within it.
FortranFan
   end associate asc
jimdempseyatthecove
I haven't tried this:
print*, (my_shape%segments(1)%make_vector())%length()
If that works, try
print*, my_shape%segments(1)%make_vector()%length() ! change . to %
Long, long ago I've experienced issues with the compiler confusing what it should do with the non-standard "." member indicate. I don't think this is the case anymore as in the former case it was a misinterpretation as to if a operator followed the . (.eq., .yourOperator., ...)
Jim Dempsey
Steve_Lionel
Ignoring the dot vs. percent syntax, the language doesn't allow you to reference a component of a function reference - it has to be a "data object" (constant, variable, or subobject of a constant).  FortranFan has one workaround.
S__MPay
Implementing associate construct as a workaround worked just fine.
This is not a . or % issue as Steve mentioned.
Actually using dot in the forum post was a typo and produces different compiler errors.
Also using
Produces:
error #5082: Syntax error, found '%' when expecting one of: .EQV. .NEQV. .XOR. .OR. .AND. .LT. < .LE. <= .EQ. == .NE. /= .GT. > ...
error #6385: The highest data type rank permitted is INTEGER(KIND=8).
error #6532: The percent character (%) has been used incorrectly.   [LENGTH]
error #6355: This binary operation is invalid for this data type.
jimdempseyatthecove
Steve,
Shouldn't the additional ()'s (suggestion 1) have produced an object reference?
Jim Dempsey
Steve_Lionel
Shouldn't the additional ()'s (suggestion 1) have produced an object reference?=
No, that makes an expression.
