Error: Product support for your (Comp-FL) license has expired
Phan__Anh
My ifort has problems when compiling programs
Error: Product support for your (Comp-FL) license has expired.
License file(s) used were (in this order):
    1.  Trusted Storage
**  2.  /opt/intel/compilers_and_libraries_2017.0.098/linux/bin/intel64/../../Licenses
**  3.  /home/anhphan/Licenses
**  4.  /opt/intel/licenses/l_V26792TK.lic
**  5.  /Users/Shared/Library/Application Support/Intel/Licenses
**  6.  /opt/intel/compilers_and_libraries_2017.0.098/linux/bin/intel64/*.lic
Please refer https://software.intel.com/en-us/faq/purchasing-renewing-upgrading#support-expiration ; for more information..
ifort: error #10052: could not checkout FLEXlm license
What should I do? Thanks
Steve_Lionel
Licensing issues need to be raised in a support request at the Intel Online Service Center.
xiyu_j_
hope you have resolved this issue.
For me, I just went to the website and renewed the Parallel Studio license file
Then it is done.
divya_sardana
Hi could you tell me the full process ...like did your download the full package and what after that ? I am new to this software.
Steve_Lionel
The current version does not require a license - it is free with "community support". Optimized Tools for HPC Apps Using Intel® oneAPI HPC Toolkit  You will also need the "Base" toolkit but can customize the install to select only the "Intel Distribution for GDB" component, to get Fortran debugger support.
saisandri
Dear Steve
I have installed both. But the problem remains same. I have also given the path in bashrc file.
Thank You
Steve_Lionel
Please show a log of your command session from the start to the point of error. If you are properly configuring for the oneAPI compiler, you won't get this error.
yinlongbin
Do you solve it ? I also have the question
Steve_Lionel
Same answer as I gave above.
Kamyar1
Hi, steve,
I've downloaded the current free version, but still, I'm getting the same error!
though I had the previous version which the license was expired, and I did not find any way to uninstall the previous version.
Thanks for your help.
mecej4
Did you install the current version after downloading it? Did you use the Start Menu shortcut for Intel OneAPI 2021, or did you attempt to build inside Visual Studio? Details regarding what you did before you got the error are necessary before remedies can be suggested.
Kamyar1
yes, I installed the base kit and the current version, and I'm a mac user.
I'm not able to find any app with the " Intel OneAPI 2021" name in the app list.
the error starts with this :
Error: Product support for your (Comp-FM) license has expired.
I could find this:
Kamyar1
My problem is solved, and ifort compiler is working now. I did these steps:
1. after installing the " Intel OneAPI 2021", I drag and drop the app to the application list.
2.  I used . /opt/intel/oneapi/setvars.sh command line in terminal
this is the result:
:: initializing oneAPI environment ...
   -zsh: ZSH_VERSION = 5.8
:: advisor -- latest
:: compiler -- latest
:: dal -- latest
:: dev-utilities -- latest
:: dnnl -- latest
:: intelpython -- latest
:: ipp -- latest
:: ippcp -- latest
:: mkl -- latest
:: tbb -- latest
:: vtune_profiler -- latest
:: oneAPI environment initialized ::
