28456 Discussions
Error: Symbol ‘iyr’ at (1) has no IMPLICIT type
negar
I am working on a model which I have sent in this link
https://drive.google.com/file/d/19oZHI-hwwrmdrW3_rSnBFR7YMkUgjEx6/view?usp=sharing
, and I had the following error when I made it:
physiology.f:1065:11:
         iyr = iyear - 1860 + 1
           1
makefile:106: recipe for target 'physiology.o' failed
make: *** [physiology.o] Error 1
Could somebody help me?
I would really appreciate it
Arjen_Markus
Honored Contributor I
Apparently, the variable iyr has not been declared and the code contains a statement "IMPLICIT NONE" or the compiler options instruct the compiler to complain about any variables that are not explicitly declared. The solution is to properly declare it:
integer :: iyr
for instance in the declaration part of the routine that contains the variable.
negar
I have added integer iyr to the source code like below, and it ran.
      integer iyear    ! current year
       integer iyr
c
      real co2init,    ! input atmospheric co2 concentration
     >     co2conc     ! output " for year iyear
c
c calculate co2 concentration for this year
c
     if (iyear.lt.1860) then
c
        co2conc = co2init
c
     else
c
c 1992 IPCC estimates
c
c       iyr = iyear - 1860 + 1
c       co2conc = (297.12 - 0.26716 * iyr +
c    >                      0.0015368 * iyr**2 +
c    >                      3.451e-5 * iyr**3) * 1.e-6
c
c
c M. El Maayar: 1996 IPCC estimates
c
        co2conc = (303.514 - 0.57881 * iyr +
     >                      0.00622 * iyr**2 +
     >                      1.3e-5 * iyr**3) * 1.e-6
c
c
     end if
c
      return
      end
c
Thank you for your help
Steve_Lionel
I'll also note that this error message came from gfortran and not Intel Fortran.
JohnNichols
Valued Contributor III
@Steve_Lionel  noted:
But where is someone going to learn the benefits of intel fortran if they do not talk to the people here
Also you had a one line statement that had the sidebars -- only @Steve_Lionel - there must be a reason
Steve_Lionel
The scrollbars are interesting. I'm going to guess they're a side-effect of my using the Microsoft "Editor" plugin to the Edge browser. It provides editorial recommendations for "clearer" text - mostly by suggesting punctuation changes or removal of unnecessary words. Looking at the HTML element of my reply there, I see lots of CSS related to the plugin. Maybe the forum thinks it needs the scrollbars to view all the "content", when most of it isn't displayed.
mecej4
Or, the CSS and other markup stuff makes it so hard to calculate the size of the "payload" that gets actually displayed,  the height of the frame cannot be calculated with confidence, so let's put in a scroll bar in there.
