29488 Discussions
Error: derived-types with fixed-sized array-components involving abstract interfaces
Hans_Peschke
with ifort 11.1.064, the compilation of the following code results in a strange error message:
[plain]module cari
implicit none
integer, parameter :: prec = kind(0.0D0)
end module cari
module functions
use cari
implicit none
abstract interface
pure function mapping() result(res)
use cari
! real :: res !! works
real(prec) :: res !! error
! integer :: res !! error
end function mapping
end interface
type type_A
procedure(mapping), nopass, pointer :: f
real, dimension(0:2) :: xrange
end type
! the following code is not involved, but D is what I need ;-)
type type_B
type(type_A), dimension(0:2) :: D
end type
end module functions
program test
!use ...
implicit none
write(*,*) 'works'
end program test[/plain]
The error appearence depends on the type of the result of the abstract interface function, if the type e.g. is integer or real(prec) (with prec=kind(0.0D0)) then the following error occurs:
[plain]$ ifort -V ifort_error_proctype2.f90
Intel Fortran Compiler Professional for applications running on IA-32, Version 11.1 Build 20091130 Package ID: l_cprof_p_11.1.064
Copyright (C) 1985-2009 Intel Corporation. All rights reserved.
FOR NON-COMMERCIAL USE ONLY
Intel Fortran 11.1-2649
ifort_error_proctype2.f90(23): error #7821: The value of array bounds must be within 2**31-1 and -2**31.
ifort_error_proctype2.f90(28): error #7821: The value of array bounds must be within 2**31-1 and -2**31.
compilation aborted for ifort_error_proctype2.f90 (code 1)
[/plain]
This is imo a wrongly error message, which should not appear.
If the type is default-real, then the error occurs not.
A very similar error appears in the following code:
[plain]module functions
implicit none
abstract interface
real :: res
end interface
type :: t1
real :: bv
integer :: y !!! error-switch !!!
end type
type :: type_A
!type(t1), dimension(0:2) :: a ! no problem
end type
type :: type_B
real, dimension(1:4) :: xr2
end type
program test
!use ...
implicit none
write(*,*) 'works'
The error appears iff the derived type t1 has an integer component:
[cpp]$ ifort -V ifort_error_proctype.f90
ifort_error_proctype.f90(21): error #7821: The value of array bounds must be within 2**31-1 and -2**31.
ifort_error_proctype.f90(22): error #7821: The value of array bounds must be within 2**31-1 and -2**31.
compilation aborted for ifort_error_proctype.f90 (code 1)
[/cpp]
Maybe there are several other circumstances in which this error appears.
Maybe this is related to http://software.intel.com/en-us/forums/showthread.php?t=70833
Best regards
Hans
Thanks. we'll take a look.
I don't think this is related to the other thread you pointed to, but one never knows. The key seems to be the declaration of a procedure pointer component of a derived type. This is corrupting the symbol table somehow so that any small perturbation can have odd effects.
You indicated that just "integer :: res" works, but it doesn't if "prec" is also declared in the local scope, even if it's not used. I'm guessing that this is really the same problem as this, which is fixed for Update 5, since it does compile ok with the latest inhouse compiler. I will ask the developers just to be sure. Issue ID is DPD200149020.
The developers confirmed that this is the same issue and is already fixed for Update 5.
Hans_Peschke
Fine, Thanks Steve.
Hans_Peschke
I only want to confirm, that the problem is solved with ifort 11.1.069
Many thanks
Hans
