29282 Discussions
Error during xild linking in compilation
Deleted_U_Intel
I've been trying to compile a substantial code (Gaussian03) with ifort and I've reached a linking stage:
xild -qipo -shared -o util.so dummy.o
--whole-archive util.a --no-whole-archive bsd/libf77blas.a bsd/libatlas.a
Which errors out with:
(0): internal error: Fatal error: dummy.il: Object's il version(1.14065.2.154) does not match the compiler's il version(1.14048).
I'm pretty sure this is caused by the atlas libs, but they were compiled with this same copy of ifort too. Does anyone have any idea whats casuing this? Or indeed any idea for a fix.
Thanks in advance
It's pretty clear that the libs were NOT generated by the same version of the compiler. If they were, you wouldn't see this error.
Are you possibly using Intel C++ instead of gcc?
frederic_bouyer
Is it possible to share experience in the compilation of gaussian03 ? I mean Makefile, and files in which you did some modifications ?
Many thanks in advance. Regards,
Frdric
