When compiling with ifort 2017 update 1:
# ifndef matrix_algebra_F90 # define matrix_algebra_F90 module matrix_algebra implicit none integer,parameter::x_=8 type::vector(size) integer,len::size complex(kind=x_)::component(0:size) contains procedure,private::initialize_vector end type vector interface vector module procedure vector_constructor end interface vector contains subroutine initialize_vector(this,source) implicit none class(vector(*))::this complex(kind=x_),intent(in),optional::source(0:this%size) if(present(source)) then this%component=source else this%component=(0.0_x_,0.0_x_) end if!present(source) end subroutine initialize_vector!this,source function vector_constructor(size,source) result(that) implicit none integer,intent(in)::size complex(kind=x_),intent(in),optional::source(0:size) type(vector(size))::that if(present(source)) then call that%initialize_vector(source) else call that%initialize_vector() end if!present(source) end function vector_constructor!size,source function test_constructor(vector0) result(vector_) implicit none type(vector(*)),intent(in)::vector0 type(vector(vector0%size))::vector_ vector_=vector(vector0%size,(0.0_x_,0.0_x_)) end function test_constructor end module matrix_algebra # endif
I get the following error:
matrix/snippet.F90(97): error #8725: If a type parameter does not have a default value, there must be a type parameter spec corresponding to that type parameter. [VECTOR] vector_=vector(vector0%size,(0.0_x_,0.0_x_)) ^ matrix/snippet.F90(97): error #6593: The number of expressions in a structure constructor differs from the number of components of the derived type. [VECTOR] vector_=vector(vector0%size,(0.0_x_,0.0_x_)) --------------------------^
This disallows me from defining custom constructors, something I was aware of being able to do. I suspect that the class name is already bound by the compiler as a synthesized constructor that simply is called to at least initialize all members with no in-class initializers (default values). In that case, the compiler prevents me from creating additional constructors to the default ones (overloading the constructor). Could you please tell me what detail I am missing here? Thank you in advance for your time.
EDIT: When using constructors in the aforementioned manner in more complex code with more types and constructors, it generates a internal compiler error, but it is certain that the constructors are the culprits, as removing all constructor calls resolves the internal error. In an attempt to make the above snippet to reproduce the problem I get a normal compiler error instead, but I think it is related still.
Here's a modified version of code in the original post that addresses the 2 issues Intel Fortran compiler didn't like but it now generates an internal compiler error, at least with the Windows version. Perhaps someone can Intel can follow up on the ICE.
module matrix_algebra implicit none integer, parameter :: x_ = 8 type :: vector(size) integer, len :: size = 1 !.. Introduce a default length parameter complex(kind=x_) :: component(0:size) contains procedure, private :: initialize_vector end type vector interface vector module procedure vector_constructor end interface vector contains subroutine initialize_vector(this, source) class(vector(size=*)) :: this complex(kind=x_), intent(in), optional :: source(0:this%size) if ( present(source) ) then this%component = source else this%component = (0.0_x_,0.0_x_) end if ! present(source) end subroutine initialize_vector ! this, source function vector_constructor( size, source ) result( that ) integer, intent(in) :: size complex(kind=x_), intent(in), optional :: source(0:size) type(vector(size)) :: that if ( present(source) ) then call that%initialize_vector( source ) else call that%initialize_vector() end if ! present(source) end function vector_constructor ! size, source function test_constructor( vector0 ) result( vector_ ) type(vector(size=*)), intent(in) :: vector0 type(vector(vector0%size)) :: vector_ vector_ = vector( vector0%size, source=[ (0.0_x_,0.0_x_) ] ) !.. Introduce a rank one array as 2nd argument end function test_constructor end module matrix_algebra
Compiling with Intel(R) Visual Fortran Compiler 17.0.1.143 [IA-32]... m.f90 fortcom: Fatal: There has been an internal compiler error (C0000005). ifort: error #10298: problem during post processing of parallel object compilation compilation aborted for m.f90 (code 1)
Thank you FortranFan. I'll follow-up and report to Development.
(Internal tracking id: DPD200416899)
This is the internal compiler error I was trying to reproduce, thank you FortranFan. In my attempt to shorten the snippet, I forgot to make the proper constructor call, which would result in the internal compiler error I am also getting on Linux. Here is what I got with the fixed code (for completeness) on 2017v1 Linux version:
/tmp/ifortCXsmaT.i90: catastrophic error: **Internal compiler error: segmentation violation signal raised** Please report this error along with the circumstances in which it occurred in a Software Problem Report. Note: File and line given may not be explicit cause of this error. compilation aborted for snippet.F90 (code 1)
