Error in overloading constructors of parametric types.
Trent_Hawkins
When compiling with ifort 2017 update 1:
#     ifndef matrix_algebra_F90
#     define matrix_algebra_F90
      module matrix_algebra
            implicit none
            integer,parameter::x_=8
            type::vector(size)
               integer,len::size
               complex(kind=x_)::component(0:size)
            contains
               procedure,private::initialize_vector
        end type  vector
            interface vector
               module procedure vector_constructor
        end interface vector
      contains
            subroutine initialize_vector(this,source)
                  implicit none
                  class(vector(*))::this
                  complex(kind=x_),intent(in),optional::source(0:this%size)
                  if(present(source)) then
                     this%component=source
                  else
                     this%component=(0.0_x_,0.0_x_)
              end if!present(source)
        end subroutine initialize_vector!this,source
            function vector_constructor(size,source) result(that)
                  implicit none
                  integer,intent(in)::size
                  complex(kind=x_),intent(in),optional::source(0:size)
                  type(vector(size))::that
                     call that%initialize_vector(source)
                  else
                     call that%initialize_vector()
        end function vector_constructor!size,source
            function test_constructor(vector0) result(vector_)
                  implicit none
                  type(vector(*)),intent(in)::vector0
                  type(vector(vector0%size))::vector_
                  vector_=vector(vector0%size,(0.0_x_,0.0_x_))
        end function test_constructor
  end module matrix_algebra
#     endif
I get the following error:
matrix/snippet.F90(97): error #8725: If a type parameter does not have a default value, there must be a type parameter spec corresponding to that type parameter.   [VECTOR]
matrix/snippet.F90(97): error #6593: The number of expressions in a structure constructor differs from the number of components of the derived type.   [VECTOR]
This disallows me from defining custom constructors, something I was aware of being able to do. I suspect that the class name is already bound by the compiler as a synthesized constructor that simply is called to at least initialize all members with no in-class initializers (default values). In that case, the compiler prevents me from creating additional constructors to the default ones (overloading the constructor). Could you please tell me what detail I am missing here? Thank you in advance for your time.
EDIT: When using constructors in the aforementioned manner in more complex code with more types and constructors, it generates a internal compiler error, but it is certain that the constructors are the culprits, as removing all constructor calls resolves the internal error. In an attempt to make the above snippet to reproduce the problem I get a normal compiler error instead, but I think it is related still.
FortranFan
Here's a modified version of code in the original post that addresses the 2 issues Intel Fortran compiler didn't like but it now generates an internal compiler error, at least with the Windows version.  Perhaps someone can Intel can follow up on the ICE.
   implicit none
   integer, parameter :: x_ = 8
   type :: vector(size)
      integer, len :: size = 1  !.. Introduce a default length parameter
      complex(kind=x_) :: component(0:size)
   contains
      procedure, private :: initialize_vector
   end type  vector
   interface vector
contains
   subroutine initialize_vector(this, source)
      class(vector(size=*))                  :: this
      complex(kind=x_), intent(in), optional :: source(0:this%size)
      if ( present(source) ) then
         this%component = source
      else
         this%component = (0.0_x_,0.0_x_)
      end if ! present(source)
   end subroutine initialize_vector ! this, source
   function vector_constructor( size, source ) result( that )
      integer, intent(in)                    :: size
      complex(kind=x_), intent(in), optional :: source(0:size)
      type(vector(size)) :: that
         call that%initialize_vector( source )
      else
   end function vector_constructor ! size, source
   function test_constructor( vector0 ) result( vector_ )
      type(vector(size=*)), intent(in) :: vector0
      type(vector(vector0%size)) :: vector_
      vector_ = vector( vector0%size, source=[ (0.0_x_,0.0_x_) ] )  !.. Introduce a rank one array as 2nd argument
Compiling with Intel(R) Visual Fortran Compiler 17.0.1.143 [IA-32]...
m.f90
fortcom: Fatal: There has been an internal compiler error (C0000005).
ifort: error #10298: problem during post processing of parallel object compilation
compilation aborted for m.f90 (code 1)
Kevin_D_Intel
Thank you FortranFan. I'll follow-up and report to Development.
(Internal tracking id: DPD200416899)
Trent_Hawkins
This is the internal compiler error I was trying to reproduce, thank you FortranFan. In my attempt to shorten the snippet, I forgot to make the proper constructor call, which would result in the internal compiler error I am also getting on Linux. Here is what I got with the fixed code (for completeness) on 2017v1 Linux version:
/tmp/ifortCXsmaT.i90: catastrophic error: **Internal compiler error: segmentation violation signal raised**
Please report this error along with the circumstances in which it occurred in a Software Problem Report.
Note: File and line given may not be explicit cause of this error.
compilation aborted for snippet.F90 (code 1)
