29656 Discussions
Error linking Intel OneAPI and ANSYS
YaxiongChen
ANSYS manual recommends to use the following compiler: Microsoft visual studio Professional 2017, Intel C++ 2019.3.203 and FORTRAN 2019.3.203. However, I could not  find the download for C++ and FORTRAN compiler.
Some post suggests to use Intel OneAPI instead. So I install OneAPI , and run  IntelAPI tools with administrative privilege. Then I made a small change in ANSCUST.BAT, replacing compilervars.bat with setvars.bat. But I got the following error.
mecej4
Few of us in this forum use or have access to ANSYS. You only show us the error message, but not the link step command line. What I can tell is from the error message is that the compilation succeeded and produced an OBJ file, but the next step failed -- the step of linking the OBJ and appropriate libraries in order to generate a DLL. Post the contents of the batch file that you used, or at least the link command line.
It is possible that the version of ANSYS that you have cannot work with the OneAPI compiler and libraries, because some of the library routine names may have been changed.
YaxiongChen
I am running a following batch file. Can you find something from it?  Can @Steve_Lionel help with it? Thanks
@echo off
cls
rem These need to change, for each new release. You might need to change
rem the SetParameters function, if the compiler changes. Otherwise, the
rem rest of the script should not need changing.
rem
set "revndot=20.2"
set "revncust=2020 R2"
set "ROOT_DIR=%AWP_ROOT202%"
set "VSVER=vs2017"
set "IFORT_HOME=%IFORT_COMPILER19%"
set "VCINPATH=%VS2017INSTALLDIR%\VC\Tools\MSVC\14.10.25017"
rem Yes, we are saving the current working directory, and we chdir back
rem into it, at various points in this script. Normally, this script is
rem run from a cmd.exe prompt, and it works fine without this. But, we
rem have automated test scripts, that call this script, and things fail,
rem if we don't explicitly move back into the working directory.
set "ACWORKDIR=%cd%"
rem :::::::::::::::::::::::::::::::
rem :: ::
rem :: E X E C U T I V E ::
rem :: ::
call :SetParameters || goto :END
call :ShowBanner || goto :END
call :AskAboutAero || goto :END
call :CompileStuff || goto :END
call :LinkStuff || goto :END
call :CopyDlls || goto :END
goto :END
rem :: ::
rem :: F U N C T I O N S ::
rem :: ::
:SetParameters
set "PLATFORM_DIR=winx64"
set "IFORT_PLATFORM=intel64"
set "BIT_TARGET=64"
call "%IFORT_HOME%\bin\setvars.bat" %IFORT_PLATFORM% %VSVER%
set "INCLUDE=%ROOT_DIR%\ansys\customize\Include;%INCLUDE%"
set "LIB=%ROOT_DIR%\ansys\Custom\Lib\%PLATFORM_DIR%;%LIB%"
exit /B 0
:ShowBanner
echo.
echo. ***********************************************************************
echo.
echo. This is the Mechanical APDL revision %revncust% ANSCUST batch file. It is
echo. used to link User Programmable Features, into versions of the M-APDL
echo. program, on Microsoft Windows %BIT_TARGET%-bit systems.
echo.
echo. ****** IMPORTANT !!!! ******
echo.
echo. The provided user subroutine source files reside in this folder:
echo. {InstallDir}\customize\user\
echo.
echo. Please copy the source file^(s^), that you wish to modify, from the above
echo. folder, into your working folder, to include them in your link. ^(The
echo. default working folder is {InstallDir}\custom\user\%PLATFORM_DIR%\ .^)
echo.
echo. If you want to use a different working folder, then also copy these other
echo. files, from the default working folder, to your actual working folder:
echo.
echo. ANSCUST.BAT
echo. ansysex.def
echo. ansys.lrf files
echo. app.manifest
echo.
echo. When you are done copying, run ANSCUST.BAT from your working folder.
echo.
pause
exit /B 0
:AskAboutAero
set "AERO=FALSE"
set /A ECNT=10
:AAA1
echo.
set /P ANSW=Do you want to link the Wind Turbine Aeroelastic library with Mechanical APDL? (Y or N):
if /I "%ANSW%"=="Y" (
set "AERO=TRUE"
exit /B 0
) else if /I "%ANSW%"=="N" (
set "AERO=FALSE"
exit /B 0
) else (
set /a ECNT=ECNT-1
if "%ECNT%"=="0" (
echo.
echo. giving up ...
echo.
exit /B 1
echo.
echo. Please answer Y or N
echo.
goto :AAA1
:CompileStuff
setlocal EnableDelayedExpansion
cd "%ACWORKDIR%"
del /q compile.log compile_error.txt >NUL 2>&1
if exist *.obj ( del /Q *.obj >NUL 2>&1 )
if exist ANSYS.exe ( del /Q ANSYS.exe >NUL 2>&1 )
if exist ANSYS.exp ( del /Q ANSYS.exp >NUL 2>&1 )
if exist ANSYS.lib ( del /Q ANSYS.lib >NUL 2>&1 )
if exist ANSYS.map ( del /Q ANSYS.map >NUL 2>&1 )
set "CUSTMACROS=/DNOSTDCALL /DARGTRAIL /DPCWIN64_SYS /DPCWINX64_SYS /DPCWINNT_SYS /DCADOE_ANSYS"
set "CMACS=/DCURVEFIT_EXPORTS /D_X86=1 /DOS_WIN32 /DWIN32 /D__STDC__"
set "CSWITCH=/O2 /Gy- /EHsc /Zi /c /W3 /MD"
set "FMACS=/D__EFL /DFORTRAN"
set "FSWITCH= /O2 /fpp /4Yportlib /auto /c /Fo.\ /MD /watch:source"
if exist *.F (
rem The "logo" is the banner that the compilers print-out, when they first
rem start processing. We only want to see that once, for each type of file
rem we process.
rem
set "LOGOMAC="
for /F "usebackq tokens=*" %%P in ( `dir /B "*.F"` ) do (
echo.
echo. compiling Fortran file %%P
echo.
ifort !LOGOMAC! %CUSTMACROS% %FMACS% %FSWITCH% %%P >>compile.log 2>&1
set "LOGOMAC=/nologo"
if exist *.c (
set "LOGOMAC="
for /F "usebackq tokens=*" %%P in ( `dir /B "*.c"` ) do (
echo.
echo. compiling C file %%P
echo.
cl !LOGOMAC! %CUSTMACROS% %CMACS% /D__MS_VC_INSTALL_PATH="%VCINPATH%" %CSWITCH% %%P >>compile.log 2>&1
if exist *.cpp (
set "LOGOMAC="
for /F "usebackq tokens=*" %%P in ( `dir /B "*.cpp"` ) do (
echo.
echo. compiling C++ file %%P
echo.
rem cl !LOGOMAC! %CUSTMACROS% %CMACS% %CSWITCH% %%P >>compile.log 2>&1
if not exist compile.log (
echo.
echo. no local files to compile - is this what you wanted?
echo.
) else (
findstr /I /C:": error" compile.log >compile_error.txt
if !errorlevel!==0 (
@echo off
echo.
echo. ******************************************************************************
echo.
echo. COMPILER ERROR! CHECK compile.log FOR MORE INFORMATION
echo.
echo.
echo.
endlocal
exit /B 1
del /Q compile_error.txt
endlocal
exit /B 0
:LinkStuff
cd "%ACWORKDIR%"
if exist ANSYS.exe ( del /Q ANSYS.exe )
if "%AERO%" == "TRUE" (
type ansys.lrf >ansys.lrf.sav
echo "%ROOT_DIR%\ansys\Custom\User\%PLATFORM_DIR%\Aeroelastic\*.obj">>ansys.lrf
link @ansys.lrf 2>&1 | findstr /V /R /c:"^ansyslib..lib.* LNK4099: PDB" /c:"^zlibwapi.lib.* LNK4099: PDB"
type ansys.lrf.sav >ansys.lrf
del /q ansys.lrf.sav
) else (
if %ERRORLEVEL% GEQ 1 (
set "ltxt=LINK ERROR!"
set enum=1
) else if not exist ansys.exe (
set enum=1
) else (
set "ltxt=Link was successful!"
set enum=0
echo.
echo.
echo. %ltxt%
echo.
echo.
exit /B %enum%
:CopyDlls
rem We offer this, because some customers have multiple versions of ANSYS/MAPDL
rem in their paths. By copying libraries here, we guarantee that if they run
rem this custom version, it will link with the correct version of the libraries.
rem
cd "%ACWORKDIR%"
echo.
echo.
echo. The next question will give you the opportunity to copy the necessary
echo. runtime DLLs. Note, this only needs to be done once. You can answer
echo. "N" for all subsequent invocations of %0.
echo.
echo.
:CD1
set /P "ANSW=Do you want to copy the runtime DLLs? (Y or N): "
copy /y "%ROOT_DIR%\ansys\Bin\%PLATFORM_DIR%\"*.dll .
copy /y "%ROOT_DIR%\commonfiles\AAS\bin\%PLATFORM_DIR%\"*.dll .
exit /B 0
exit /B 0
) else (
echo.
echo "Please answer Y or N!"
echo.
goto CD1
exit /B 0
:END
endlocal
andrew_4619
your scripts has:
So it seems you want the VC TOOLS path. I do not know if that is correct for your system but I would suggest:
"VCINPATH=%VCToolsInstallDir%
As that is what the setvars from OneAPI sets on my system that is
VCToolsInstallDir=C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023\
mecej4
That batch file is rather long, and probably impossible to debug without having ANSYS installed. As far  as I can see, the link command is
For this to work, the earlier commands in the batch file should have placed a list of names of OBJ (and, possibly, LIB) files into the file ansys.lrf. You can see if you have that file, and list the file. If the expected usermat.OBJ is not present, you could investigate the causes. If the file is present and looks proper, you could try the command
     link @ansys.lrf
and this command would let you see any error messages from the linker, which the redirection 2>&1 may have hidden.
These matters are more appropriate for discussion in a forum for ANSYS users.
Bley_Vinci
Have you found a solution, please?
