Error re-installing v10.0
engineerik
I use IVF 10.0 integrated with my VS2005PRO on a compaq presario machine w/ AMD Athelon processor and 960MB RAM. The OS is XP home 2002 edition SP3. I installed IVF 10.0 a little over a year ago and have been using it with no problems. Unfortunately, I recently experienced some trouble with a virus. I had to reload windows. After performing a system restore all my files were fine but I had to reload most of my software. There seemed to be some issues with VS2005 related to .NET framework installation. I had to uninstall all .NET Framework versions and that seemed to take care of the issues with VS2005. When I try to run the IVF install from the CD I get the following error message.
SetupCore.exe - application error
The application failed to initialize properly (0xc0000006). Click on OK to terminate the application.
Any idea what this is about?
Erik Warren
TimP
If you're looking for suggestions:
1. Did you re-apply VS2005 SP1? Is VS2005 working for a simple C or C++ case?
2. Any update of ifort 10.0 would be preferable to the CD version, although that doesn't explain installation problems.
TimP
As Tim suggests, please download the latest ifort you can get from the Intel Registration Center. I also suggest a reboot before you try the install.
engineerik
Quoting - tim18
1. No, I am working with VS2005 without SP1 due to the target machines for the main application I am working on are controlled machines that do not get updates and do not have the required versions of some dlls.
I have reinstalled .NET Framework up to 2.0 SP1 and VS2005 is behaving perfectly now that I straightened out the .NET framework installation.
2. I will try downloading v10.1 and see if it will install.
engineerik
Quoting - tim18
Success!
Just downloaded v10.1 and it installed without a hitch.
Erik Warren
