I'm trying to set the variables after installing the packages intel-basekit and intel-hpckit through the apt package manager. No issues occurred during installation.
When I try to source the variables using the setvars.sh script, I get the following error.
:: initializing oneAPI environment ...
bash: BASH_VERSION = 5.0.17(1)-release
args: Using "$@" for setvars.sh arguments:
:: ERROR: No env scripts found: No "env/vars.sh" scripts to process.
This can be caused by a bad or incomplete "--config" file.
Can also be caused by an incomplete or missing oneAPI installation.
I've read through the documentation in length and couldn't find answers.
Following this answer for zsh shells here, I tried running
bash -c 'source setvars.sh'
bash -c 'source /opt/intel/oneapi/compiler/latest/env/vars.sh'
There were no immediate errors, and the environment appeared to be initialized. The $PATH and $LD_LIBRARY_PATH variables contain /opt/intel/oneapi... paths in them. However, when I run ifort to compile a basic program, it throws the error:
ld: cannot find -lgcc
ld: cannot find -lgcc_s
My system details are the following:
$ lsb_release -a
Distributor ID: Ubuntu
Description: Ubuntu 20.04.4 LTS
Release: 20.04
Codename: focal
$ uname -r
5.15.0-46-generic
$ uname -m
x86_64
strange - I tried to set that alias and no issue. I also changed link /bin/sh to /bin/dash. no issues.
$ alias
alias ls='ls --color=auto'
rwgreen@orcsle156:~$ !source
source /cts/tools/oneapi/2022.2.0-up1/setvars.sh
-bash: BASH_VERSION = 5.0.17(1)-release
:: advisor -- latest
:: ccl -- latest
:: clck -- latest
:: compiler -- latest
:: dal -- latest
:: debugger -- latest
:: dev-utilities -- latest
:: dnnl -- latest
:: dpcpp-ct -- latest
:: dpl -- latest
:: inspector -- latest
:: intelpython -- latest
:: ipp -- latest
:: ippcp -- latest
:: ipp -- latest
:: itac -- latest
:: mkl -- latest
:: mpi -- latest
:: tbb -- latest
:: vtune -- latest
:: oneAPI environment initialized ::
setvars.sh finds all the vars.sh scripts under /opt/intel/oneapi/*/latest/env
something in creating that list is wrong. so time for the big debug hammer.
sudo bash
# to get a root sudo shell
Edit /opt/intel/oneapi/setvars.sh
first line, change
/bin/sh
to
/bin/sh -x
exit the sudo shell, go back to user.
then source setvars.sh and capture the output. like this
source /opt/intel/oneapi/setvars.sh |& tee source.log
let's see what is going wrong
Hi CJ00,
Thanks for posting your concern on the forum. However, this forum topic is to provide support on Getting Started questions (such as download, installation, etc) for Intel® oneAPI Toolkits, Intel® Parallel Studio XE and Intel® System Studio. As the mentioned query is related to post-installation, it is out of our scope.
Nonetheless, please be assured, as we are routing your post to the correct forum. Based on your query, we are moving this topic to the 'Intel® oneAPI Base Toolkit' community. Our internal team would get back to you there in a timely manner.
Hope you have a nice day ahead!
Soumya
Could you please let us know the version of Intel OneAPI toolkits you have installed?
Could you please provide us with the screenshot of the error you are facing while running the fortran code?
And also, could you let us know if you are able to get the fortran version after initializing the oneAPI environment?
ifort --version
At our end, we have tried the latest Intel oneAPI(2022.2) on Ubuntu 20.04 and we are able to get the expected results. Please find the below screenshot:
Thanks & Regards,
Varsha
Thanks for the quick response @VarshaS_Intel .
Here are the details.
$ sudo apt-cache policy intel-basekit intel-hpckit intel-basekit: Installed: 2022.2.0-262 Candidate: 2022.2.0-262 intel-hpckit: Installed: 2022.2.0-191 Candidate: 2022.2.0-191
When I run bash -c 'source /opt/intel/oneapi/setvars.sh', the same initialization details are printed out as in your screenshot.
If I check for ifort after that, I get:
$ ifort --version Command 'ifort' not found, did you mean: command 'isort' from deb isort (4.3.4+ds1-2) command 'fort' from deb fort-validator (1.2.0-1)
However if I run, the source and ifort commands in the same command string, ifort appears to be available as below
$ bash -c 'source /opt/intel/oneapi/setvars.sh; ifort --version' :: initializing oneAPI environment ... bash: BASH_VERSION = 5.0.17(1)-release args: Using "$@" for setvars.sh arguments: :: advisor -- latest :: ccl -- latest :: clck -- latest :: compiler -- latest :: dal -- latest :: debugger -- latest :: dev-utilities -- latest :: dnnl -- latest :: dpcpp-ct -- latest :: dpl -- latest :: inspector -- latest :: intelpython -- latest :: ipp -- latest :: ippcp -- latest :: ipp -- latest :: itac -- latest :: mkl -- latest :: mpi -- latest :: tbb -- latest :: vpl -- latest :: vtune -- latest :: oneAPI environment initialized :: ifort (IFORT) 2021.6.0 20220226 Copyright (C) 1985-2022 Intel Corporation. All rights reserved.
Let me clarify that the primary issue I face is that even though I use the bash terminal I'm unable to run
and can instead only do
The latter cannot be placed in a file like .bashrc as explained in this post in the Intel forums by @Ron_Green , so I keep having to set variables every time I open/split into a terminal.
I hope I haven't made it confusing.
CJ
First, on your base terminal, what do you get from
echo $SHELL
Ideally, this will show as /bin/bash. If you see zsh, you need to add a step to the line you are using to source. See the original thread you linked, but you should instead use:
bash -c 'source /opt/intel/oneapi/setvars.sh ; exec zsh'
Make sure you keep the exec zsh part, this puts you back into zsh while keeping the environment variables set by the bash script. You also only need the setvars, this should find the vars needed from each of the components.
Regarding the linker errors. The compilers depend on system runtime libraries, and need the development versions of those installed as well. I'm surprised these weren't automatically installed via APT, but you can get them directly using the following:
sudo apt install build-essential
This should take care of the linker errors you are encountering.
@James_T_Intel thanks for the follow up.
I must say, I'm a very bash person. I've never used any of these fancier shells, zsh and what not! Unsurprisingly, this is what I get for the SHELL variable.
$ echo $SHELL /bin/bash
I think the linker errors were a consequence of the environment variables not being intialized correctly. APT had handled the dependency during installation.
Finally, this is what works for me at the moment. It is very odd that bash requires this to be done. I have the same issue on an other Ubuntu 20.04 system too.
bash -c 'source /opt/intel/oneapi/setvars.sh; exec bash'
Is there anyway I can include this in a script somewhere, so the variables are still available every time I split/open a new terminal?
CJ
In theory, you could "source /opt/intel/oneapi/setvars.sh" in your .bashrc, but this seems to not set your environment correctly. Let's check something. If you just start a new terminal and source the setvars script, what do you get for your $PATH environment variable?
James,
I've tried several ways to get the setvars.sh script to add the required directories to $PATH.
These are the commands I've tried that have no effect on $PATH
$ source /opt/intel/oneapi/setvars.sh
# Returns ERROR: No env scripts found
$ bash -c 'source /opt/intel/oneapi/setvars.sh'
# Executes successfully but $PATH remains the same after the command is run.
$ bash -c 'source /opt/intel/oneapi/setvars.sh; echo $PATH'
The only one that seems to work is
$ bash -c 'source /opt/intel/oneapi/setvars.sh; exec bash'
# Successfully initializes oneAPI environment
$ echo $PATH
opt/intel/oneapi/vtune/2022.3.0/bin64:/opt/intel/oneapi/vpl/2022.1.0/bin:....
# Required directories are appended to PATH variable
However, I understand this cannot be added to .bashrc or any similar script because of the 'exec bash' part at the end.
I cannot understand why I have to do 'bash -c' for it to work on a bash shell.
I understand the difficulties in trying to solve a non-reproducible issue. So, I'll work with the exec bash part included for now.
ok wait - the error you show is that it can't find gcc libraries. did you install gcc?
gcc --version
what does that show?
Thanks for jumping in on this.
gcc --version gives me
$ gcc --version
gcc (Ubuntu 9.4.0-1ubuntu1~20.04.1) 9.4.0
Ah I see - you missed a command to start a new zsh after the source. do this
this should work. if not, send the output of
ifort -# hello.f90
Ron,
bash -c 'source /opt/intel/oneapi/setvars.sh ; exec bash' does work.
But I do not use zsh or similar shells. I use bash on a freshly installed Ubuntu 20.04.
my confusion.
so you do use bash:
echo $0
-bash
maybe a bad installation?
cd /opt/intel/oneapi
find . -name vars.sh
./intelpython/python3.7/pkgs/intelpython-2021.1.1-1/env/vars.sh
./intelpython/python3.7/env/vars.sh
./intelpython/python3.7/envs/tensorflow_gpu/env/vars.sh
./intelpython/python3.7/envs/2021.1.1/env/vars.sh
./vpl/2021.1.1/env/vars.sh
./dnnl/2021.1.1/env/vars.sh
./mpi/2021.1.1/env/vars.sh
./advisor/2021.1.1/env/vars.sh
./compiler/2021.1-beta09/linux/env/vars.sh
./compiler/2021.1-beta09/linux/dpl_env/vars.sh
./compiler/2021.1.2/env/vars.sh
./mkl/2021.1.1/env/vars.sh
./tbb/2021.1.1/env/vars.sh
./vtune/2021.1.1/env/vars.sh
./dpl/2021.1.2/env/vars.sh
./dal/2021.1.1/env/vars.sh
./dpcpp-ct/2021.1.1/env/vars.sh
./ipp/2021.1.1/env/vars.sh
./dev-utilities/2021.1.1/env/vars.sh
./ccl/2021.1.1/env/vars.sh
./ippcp/2021.1.1/env/vars.sh
./debugger/10.0.0/env/vars.sh
Did you install as root or with sudo or as a normal user?
if you have a simple hello.f90 like this
print *, "hello"
end
what is the output of
ifort -# hello.f90
$0 gives me
$ echo $0
/bin/bash
Searching for vars.sh gives me
$ find /opt/intel/oneapi/ -name 'vars.sh'
/opt/intel/oneapi/mkl/2022.1.0/env/vars.sh
/opt/intel/oneapi/ccl/2021.6.0/env/vars.sh
/opt/intel/oneapi/dev-utilities/2021.6.0/env/vars.sh
/opt/intel/oneapi/dpcpp-ct/2022.1.0/env/vars.sh
/opt/intel/oneapi/dnnl/2022.1.0/env/vars.sh
/opt/intel/oneapi/intelpython/python3.9/pkgs/intelpython-2022.1.0-0/env/vars.sh
/opt/intel/oneapi/intelpython/python3.9/envs/2022.1.0/env/vars.sh
/opt/intel/oneapi/intelpython/python3.9/env/vars.sh
/opt/intel/oneapi/vpl/2022.1.0/env/vars.sh
/opt/intel/oneapi/debugger/2021.6.0/env/vars.sh
/opt/intel/oneapi/dpl/2021.7.0/env/vars.sh
/opt/intel/oneapi/itac/2021.6.0/env/vars.sh
/opt/intel/oneapi/ipp/2021.6.0/env/vars.sh
/opt/intel/oneapi/tbb/2021.6.0/env/vars.sh
/opt/intel/oneapi/dal/2021.6.0/env/vars.sh
/opt/intel/oneapi/advisor/2022.1.0/env/vars.sh
/opt/intel/oneapi/mpi/2021.6.0/env/vars.sh
/opt/intel/oneapi/inspector/2022.1.0/env/vars.sh
/opt/intel/oneapi/compiler/2022.1.0/env/vars.sh
/opt/intel/oneapi/ippcp/2021.6.0/env/vars.sh
/opt/intel/oneapi/vtune/2022.3.0/env/vars.sh
/opt/intel/oneapi/clck/2021.6.0/env/vars.sh
I installed OneAPI using the apt package manager with
$ sudo apt install intel-basekit intel-hpckit
The repository was
$ apt-cache policy intel-basekit intel-hpckit
intel-basekit:
Version table:
*** 2022.2.0-262 500
500 https://apt.repos.intel.com/oneapi all/main amd64 Packages
intel-hpckit:
Version table:
*** 2022.2.0-191 500
I can't run ifort without sourcing the setvars.sh script. If I use the ifort executable's path directly, I get
$ cat hello.f90
program hello
print*, "hello"
end program hello
$ /opt/intel/oneapi/compiler/latest/linux/bin/intel64/ifort --version
$ /opt/intel/oneapi/compiler/latest/linux/bin/intel64/ifort -# hello.f90
/opt/intel/oneapi/compiler/2022.1.0/linux/bin/intel64/../../bin/intel64/fortcom \
-D__INTEL_COMPILER=2021 \
-D__INTEL_COMPILER_UPDATE=6 \
-D__unix__ \
-D__unix \
-D__linux__ \
-D__linux \
-D__gnu_linux__ \
-Dunix \
-Dlinux \
-D__ELF__ \
-D__x86_64 \
-D__x86_64__ \
-D__amd64 \
-D__amd64__ \
-D__INTEL_COMPILER_BUILD_DATE=20220226 \
-D__INTEL_OFFLOAD \
-D__MMX__ \
-D__SSE__ \
-D__SSE_MATH__ \
-D__SSE2__ \
-D__SSE2_MATH__ \
-D__pentium4 \
-D__pentium4__ \
-D__tune_pentium4__ \
-I. \
-I/opt/intel/oneapi/compiler/2022.1.0/linux/bin/intel64/../../compiler/include/intel64 \
-I/opt/intel/oneapi/compiler/2022.1.0/linux/bin/intel64/../../compiler/include/icc \
-I/opt/intel/oneapi/compiler/2022.1.0/linux/bin/intel64/../../compiler/include \
-I/usr/local/include \
-I/usr/lib/gcc/x86_64-linux-gnu/9/include \
-I/usr/include/ \
-I/usr/include \
-I/usr/include/x86_64-linux-gnu \
-omp_simd \
-O2 \
"-reentrancy threaded" \
-simd \
-offload_host \
-mGLOB_em64t=TRUE \
-mP1OPT_version=2021.6.0-intel64 \
-mGLOB_diag_file=/tmp/ifortcHixVY.diag \
-mGLOB_long_size_64 \
-mGLOB_routine_pointer_size_64 \
-mGLOB_source_language=GLOB_SOURCE_LANGUAGE_F90 \
-mP2OPT_static_promotion \
-mGLOB_pack_sort_init_list \
-mP1OPT_print_version=FALSE \
-mCG_use_gas_got_workaround=F \
-mP2OPT_align_option_used=TRUE \
-mGLOB_gcc_version=940 \
-mGLOB_options_string=-# \
-mGLOB_cxx_limited_range=FALSE \
-mCG_extend_parms=FALSE \
-mGLOB_compiler_bin_directory=/opt/intel/oneapi/compiler/2022.1.0/linux/bin/intel64/../../bin/intel64 \
-mGLOB_as_output_backup_file_name=/tmp/ifortmXBoPXas_.s \
-mGLOB_dashboard_use_source_name \
-mIPOPT_activate \
-mIPOPT_lite \
-mGLOB_uarch_tuning=0x0 \
-mGLOB_product_id_code=0x22006d91 \
-mCG_bnl_movbe=T \
-mP3OPT_use_mspp_call_convention \
-mP2OPT_subs_out_of_bound=FALSE \
-mP2OPT_disam_type_based_disam=2 \
-mGLOB_ansi_alias \
-mPGOPTI_value_profile_use=T \
-mGLOB_opt_report_use_source_name \
-mGLOB_offload_mode=1 \
-mGLOB_offload_no_openmp=TRUE \
-mP2OPT_offload_unique_var_string=ifort1117675979RF5JDZ \
-mP2OPT_hlo_level=2 \
-mP2OPT_hlo \
-mP2OPT_hpo_rtt_control=0 \
-mIPOPT_args_in_regs=0 \
-mP2OPT_disam_assume_nonstd_intent_in=FALSE \
-mGLOB_imf_mapping_library=/opt/intel/oneapi/compiler/2022.1.0/linux/bin/intel64/../../bin/intel64/libiml_attr.so \
-mIPOPT_single_file_compile_and_link=TRUE \
-mPGOPTI_gen_threadsafe_level=0 \
-mIPOPT_lto_object_enabled \
-mIPOPT_lto_object_value=1 \
-mIPOPT_obj_output_file_name=/tmp/ifortcHixVY.o \
-mIPOPT_whole_archive_fixup_file_name=/tmp/ifortwarchLj8AYZ \
-mGLOB_linker_version=2.34 \
-mGLOB_linker=ld \
-mGLOB_driver_tempfile_name=/tmp/iforttempfiletpRtyZ \
-mP3OPT_asm_target=P3OPT_ASM_TARGET_GAS \
-mGLOB_async_unwind_tables=TRUE \
-mGLOB_obj_output_file=/tmp/ifortcHixVY.o \
-mGLOB_source_dialect=GLOB_SOURCE_DIALECT_FORTRAN \
-mP1OPT_source_file_name=hello.f90 \
-mP1OPT_full_source_file_name=/home/cibin/Documents/scratch/hello.f90 \
-mP2OPT_symtab_type_copy=true \
hello.f90
ld \
/usr/lib/gcc/x86_64-linux-gnu/9/../../../x86_64-linux-gnu/Scrt1.o \
/usr/lib/gcc/x86_64-linux-gnu/9/../../../x86_64-linux-gnu/crti.o \
/usr/lib/gcc/x86_64-linux-gnu/9/crtbeginS.o \
--eh-frame-hdr \
--build-id \
-dynamic-linker \
/lib64/ld-linux-x86-64.so.2 \
-m \
elf_x86_64 \
-plugin \
/opt/intel/oneapi/compiler/2022.1.0/linux/bin/intel64/../../bin/intel64/../../lib/icx-lto.so \
-o \
a.out \
/opt/intel/oneapi/compiler/2022.1.0/linux/bin/intel64/../../compiler/lib/intel64_lin/for_main.o \
-L/opt/intel/oneapi/compiler/2022.1.0/linux/bin/intel64/../../compiler/lib/intel64_lin \
-L/usr/lib/gcc/x86_64-linux-gnu/9/ \
-L/usr/lib/gcc/x86_64-linux-gnu/9/../../../x86_64-linux-gnu/ \
-L/usr/lib/gcc/x86_64-linux-gnu/9/../../../../lib64 \
-L/usr/lib/gcc/x86_64-linux-gnu/9/../../../../lib/ \
-L/lib/x86_64-linux-gnu/ \
-L/lib/../lib64 \
-L/lib/../lib/ \
-L/usr/lib/x86_64-linux-gnu/ \
-L/usr/lib/../lib64 \
-L/usr/lib/../lib/ \
-L/usr/lib/gcc/x86_64-linux-gnu/9/../../../ \
-L/lib64 \
-L/lib/ \
-L/usr/lib64 \
-L/usr/lib \
-Bdynamic \
-Bstatic \
-lifport \
-lifcoremt \
-limf \
-lsvml \
-Bdynamic \
-lm \
-Bstatic \
-lipgo \
-lirc \
-Bdynamic \
-lpthread \
-Bstatic \
-lsvml \
-Bdynamic \
-lc \
-lgcc \
-lgcc_s \
-Bstatic \
-lirc_s \
-Bdynamic \
-ldl \
-lc \
/usr/lib/gcc/x86_64-linux-gnu/9/crtendS.o \
/usr/lib/gcc/x86_64-linux-gnu/9/../../../x86_64-linux-gnu/crtn.o
rm /tmp/ifortdashvHmgie0 # and some other similar temporary files
If I run it without the -# flag, I get
$ /opt/intel/oneapi/compiler/latest/linux/bin/intel64/ifort hello.f90
ld: /opt/intel/oneapi/compiler/2022.1.0/linux/bin/intel64/../../bin/intel64/../../lib/icx-lto.so: error loading plugin: libimf.so: cannot open shared object file: No such file or directory
I think that is because setvars.sh has not been run.
ifort works without any issues with "bash -c 'source setvars.sh'; env bash". This makes me think it's not an installation issue.
Checking $0 gives me
$ echo $0
/bin/bash
Installed it using apt using sudo apt install intel-basekit intel-hpckit from the following apt repos:
intel-basekit:
Version table:
intel-hpckit:
Version table:
what do you have in ~/.bashrc file, if anything?
did you use the interactive installer or the silent installer or APT?
I do not have any scripts being sourced/executed in ~/.bashrc. Only have a few additions to $PATH.
I cannot run ifort -# without setting the env variables as the executable will not be found/available.
If I run ifort directly from the oneAPI executable's directory, I get
-D__unix__ \
-D__unix \
-D__linux__ \
-D__linux \
-D__gnu_linux__ \
-Dunix \
-Dlinux \
-D__ELF__ \
-D__x86_64 \
-D__x86_64__ \
-D__amd64 \
-D__amd64__ \
-D__INTEL_OFFLOAD \
-D__MMX__ \
-D__SSE__ \
-D__SSE_MATH__ \
-D__SSE2__ \
-D__SSE2_MATH__ \
-D__pentium4 \
-D__pentium4__ \
-I. \
-I/usr/include/ \
-I/usr/include \
-omp_simd \
-O2 \
-simd \
-offload_host \
-mGLOB_em64t=TRUE \
-mGLOB_diag_file=/tmp/ifort8zfO3i.diag \
-mGLOB_as_output_backup_file_name=/tmp/ifortRtLJeias_.s \
-mIPOPT_activate \
-mIPOPT_lite \
-mCG_bnl_movbe=T \
-mGLOB_ansi_alias \
-mP2OPT_offload_unique_var_string=ifort1154436346eSjQXh \
-mP2OPT_hlo \
-mIPOPT_obj_output_file_name=/tmp/ifort8zfO3i.o \
-mIPOPT_whole_archive_fixup_file_name=/tmp/ifortwarch0sFFUh \
-mGLOB_linker=ld \
-mGLOB_driver_tempfile_name=/tmp/iforttempfile5aRi8h \
-mGLOB_obj_output_file=/tmp/ifort8zfO3i.o \
hello.f90
ld \
--eh-frame-hdr \
--build-id \
-dynamic-linker \
-m \
elf_x86_64 \
-plugin \
-o \
a.out \
-L/lib/../lib64 \
-L/lib/../lib/ \
-L/lib64 \
-L/lib/ \
-L/usr/lib64 \
-L/usr/lib \
-Bdynamic \
-Bstatic \
-lifport \
-lifcoremt \
-limf \
-lsvml \
-Bdynamic \
-lm \
-Bstatic \
-lipgo \
-lirc \
-Bdynamic \
-lpthread \
-Bstatic \
-lsvml \
-Bdynamic \
-lc \
-lgcc \
-lgcc_s \
-Bstatic \
-lirc_s \
-Bdynamic \
-ldl \
-lc \
rm /tmp/ifortdashvauM1ag # And some other tmp files
CJ,
a few questions
This is Ubu 20.04. Is this a workstation or server running Ubuntu, or is this a VM, a container, or WSL 2.0?
next you said "When I try to source the variables using the setvars.sh script, I get the following error."
<snip>
your command is just
correct?
Do you have sh as a sym link to bash?
ls -l /bin/sh
lrwxrwxrwx 1 root root 4 Oct 26 2020 /bin/sh -> bash
a few more questions or tests
which ln
/usr/bin/ln
which ls
/usr/bin/ls
and do you have aliases, particularly for 'ls'?
alias
Did your 'latest' links get created?
ls -l /opt/intel/oneapi/*/*/env/vars.sh
-rwxr-xr-x 1 root root 1652 Nov 11 2020 /opt/intel/oneapi/advisor/2021.1.1/env/vars.sh
-rwxr-xr-x 1 root root 1652 Nov 11 2020 /opt/intel/oneapi/advisor/latest/env/vars.sh
-rwxr-xr-x 1 root root 4505 Nov 5 2020 /opt/intel/oneapi/ccl/2021.1.1/env/vars.sh
-rwxr-xr-x 1 root root 4505 Nov 5 2020 /opt/intel/oneapi/ccl/latest/env/vars.sh
-rwxr-xr-x 1 root root 7949 Dec 14 2020 /opt/intel/oneapi/compiler/2021.1.2/env/vars.sh
-rwxr-xr-x 1 root root 7949 Dec 14 2020 /opt/intel/oneapi/compiler/latest/env/vars.sh
-rwxr-xr-x 1 root root 4038 Nov 11 2020 /opt/intel/oneapi/dal/2021.1.1/env/vars.sh
-rwxr-xr-x 1 root root 4038 Nov 11 2020 /opt/intel/oneapi/dal/latest/env/vars.sh
-rwxr-xr-x 1 root root 4961 Nov 4 2020 /opt/intel/oneapi/debugger/10.0.0/env/vars.sh
-rwxr-xr-x 1 root root 4961 Nov 4 2020 /opt/intel/oneapi/debugger/latest/env/vars.sh
-rw-rw-r-- 1 root root 5300 Nov 9 2020 /opt/intel/oneapi/dev-utilities/2021.1.1/env/vars.sh
-rw-rw-r-- 1 root root 5300 Nov 9 2020 /opt/intel/oneapi/dev-utilities/latest/env/vars.sh
-rwxr-xr-x 1 root root 5591 Nov 11 2020 /opt/intel/oneapi/dnnl/2021.1.1/env/vars.sh
-rwxr-xr-x 1 root root 5591 Nov 11 2020 /opt/intel/oneapi/dnnl/latest/env/vars.sh
-rwxr-xr-x 1 root root 4006 Nov 3 2020 /opt/intel/oneapi/dpcpp-ct/2021.1.1/env/vars.sh
-rwxr-xr-x 1 root root 4006 Nov 3 2020 /opt/intel/oneapi/dpcpp-ct/latest/env/vars.sh
-rwxr-xr-x 1 root root 4494 Oct 15 2020 /opt/intel/oneapi/dpl/2021.1.2/env/vars.sh
-rwxr-xr-x 1 root root 4494 Oct 15 2020 /opt/intel/oneapi/dpl/latest/env/vars.sh
-rw-rw-r-- 1 19712 12137 4065 Nov 11 2020 /opt/intel/oneapi/intelpython/latest/env/vars.sh
-rw-rw-r-- 1 19712 12137 4065 Nov 11 2020 /opt/intel/oneapi/intelpython/python3.7/env/vars.sh
-rwxrwxr-x 1 root root 3590 Nov 12 2020 /opt/intel/oneapi/ipp/2021.1.1/env/vars.sh
-rwxrwxr-x 1 root root 3813 Nov 5 2020 /opt/intel/oneapi/ippcp/2021.1.1/env/vars.sh
-rwxrwxr-x 1 root root 3813 Nov 5 2020 /opt/intel/oneapi/ippcp/latest/env/vars.sh
-rwxrwxr-x 1 root root 3590 Nov 12 2020 /opt/intel/oneapi/ipp/latest/env/vars.sh
-rwxr-xr-x 1 root root 7922 Nov 4 2020 /opt/intel/oneapi/mkl/2021.1.1/env/vars.sh
-rwxr-xr-x 1 root root 7922 Nov 4 2020 /opt/intel/oneapi/mkl/latest/env/vars.sh
-rw-r--r-- 1 root root 6275 Nov 12 2020 /opt/intel/oneapi/mpi/2021.1.1/env/vars.sh
-rw-r--r-- 1 root root 6275 Nov 12 2020 /opt/intel/oneapi/mpi/latest/env/vars.sh
-rw-r--r-- 1 root root 2070 Oct 20 2020 /opt/intel/oneapi/tbb/2021.1.1/env/vars.sh
-rw-r--r-- 1 root root 2070 Oct 20 2020 /opt/intel/oneapi/tbb/latest/env/vars.sh
-rw-r--r-- 1 root root 3828 Oct 30 2020 /opt/intel/oneapi/vpl/2021.1.1/env/vars.sh
-rw-r--r-- 1 root root 3828 Oct 30 2020 /opt/intel/oneapi/vpl/latest/env/vars.sh
-rwxr-xr-x 1 root root 1599 Nov 10 2020 /opt/intel/oneapi/vtune/2021.1.1/env/vars.sh
-rwxr-xr-x 1 root root 1599 Nov 10 2020 /opt/intel/oneapi/vtune/latest/env/vars.sh
Ron,
This is on a Dell Inspiron laptop running Ubuntu 20.04.
I also have access to a workstation running Ubuntu 20.04 that I'm checking these queries against. It has responded identically so far.
I have run 'source setvars.sh' and 'bash -c 'source setvars.sh''. Without the 'bash -c' the script throws an error.
$ # This throws an error
$ source setvars.sh
$ # This does not throw an error
$ bash -c 'source setvars.sh'
# ... list of all other components ...
:: vtune -- latest
ls is a link to dash (not bash). Which is pretty standard I guess?
$ ls -l /bin/sh
lrwxrwxrwx 1 root root 4 Aug 15 14:32 /bin/sh -> dash
The ls and ln commands are from /usr/bin.
$ which ln
/usr/bin/ln
$ which ls
/usr/bin/ls
$ alias ls
The links to the 'latest' directory seem to have been created too.
$ ls -l /opt/intel/oneapi/*/*/env/vars.sh
-rwxr-xr-x 1 root root 2668 Mar 25 17:08 /opt/intel/oneapi/advisor/2022.1.0/env/vars.sh
-rwxr-xr-x 1 root root 2668 Mar 25 17:08 /opt/intel/oneapi/advisor/latest/env/vars.sh
-rwxr-xr-x 1 root root 5654 Mar 11 15:55 /opt/intel/oneapi/ccl/2021.6.0/env/vars.sh
-rwxr-xr-x 1 root root 5654 Mar 11 15:55 /opt/intel/oneapi/ccl/latest/env/vars.sh
-rw-r--r-- 1 root root 9148 Mar 29 19:38 /opt/intel/oneapi/clck/2021.6.0/env/vars.sh
-rw-r--r-- 1 root root 9148 Mar 29 19:38 /opt/intel/oneapi/clck/latest/env/vars.sh
-rwxr-xr-x 1 root root 12392 Mar 16 23:50 /opt/intel/oneapi/compiler/2022.1.0/env/vars.sh
-rwxr-xr-x 1 root root 12392 Mar 16 23:50 /opt/intel/oneapi/compiler/latest/env/vars.sh
-rwxr-xr-x 1 root root 9542 Mar 5 05:26 /opt/intel/oneapi/dal/2021.6.0/env/vars.sh
-rwxr-xr-x 1 root root 9542 Mar 5 05:26 /opt/intel/oneapi/dal/latest/env/vars.sh
-rw-r--r-- 1 root root 6220 Mar 17 20:45 /opt/intel/oneapi/debugger/2021.6.0/env/vars.sh
-rw-r--r-- 1 root root 6220 Mar 17 20:45 /opt/intel/oneapi/debugger/latest/env/vars.sh
-rw-r--r-- 1 root root 7844 Mar 17 21:19 /opt/intel/oneapi/dev-utilities/2021.6.0/env/vars.sh
-rw-r--r-- 1 root root 7844 Mar 17 21:19 /opt/intel/oneapi/dev-utilities/latest/env/vars.sh
-rwxr-xr-x 1 root root 7602 Mar 29 02:53 /opt/intel/oneapi/dnnl/2022.1.0/env/vars.sh
-rwxr-xr-x 1 root root 7602 Mar 29 02:53 /opt/intel/oneapi/dnnl/latest/env/vars.sh
-rwxr-xr-x 1 root root 5445 Mar 1 08:45 /opt/intel/oneapi/dpcpp-ct/2022.1.0/env/vars.sh
-rwxr-xr-x 1 root root 5445 Mar 1 08:45 /opt/intel/oneapi/dpcpp-ct/latest/env/vars.sh
-rwxr-xr-x 1 root root 7430 Mar 10 15:57 /opt/intel/oneapi/dpl/2021.7.0/env/vars.sh
-rwxr-xr-x 1 root root 7430 Mar 10 15:57 /opt/intel/oneapi/dpl/latest/env/vars.sh
-rwxr-xr-x 1 root root 1885 Mar 4 06:20 /opt/intel/oneapi/inspector/2022.1.0/env/vars.sh
-rwxr-xr-x 1 root root 1885 Mar 4 06:20 /opt/intel/oneapi/inspector/latest/env/vars.sh
-rw-rw-r-- 1 root root 11929 Jan 12 2022 /opt/intel/oneapi/intelpython/latest/env/vars.sh
-rw-rw-r-- 1 root root 11929 Jan 12 2022 /opt/intel/oneapi/intelpython/python3.9/env/vars.sh
-rwxrwxr-x 1 root root 5975 Mar 9 02:28 /opt/intel/oneapi/ipp/2021.6.0/env/vars.sh
-rwxrwxr-x 1 root root 6335 Feb 28 02:55 /opt/intel/oneapi/ippcp/2021.6.0/env/vars.sh
-rwxrwxr-x 1 root root 6335 Feb 28 02:55 /opt/intel/oneapi/ippcp/latest/env/vars.sh
-rwxrwxr-x 1 root root 5975 Mar 9 02:28 /opt/intel/oneapi/ipp/latest/env/vars.sh
-rwxr-xr-x 1 root root 6066 Mar 28 00:00 /opt/intel/oneapi/itac/2021.6.0/env/vars.sh
-rwxr-xr-x 1 root root 6066 Mar 28 00:00 /opt/intel/oneapi/itac/latest/env/vars.sh
-rwxr-xr-x 1 root root 11614 Mar 11 10:41 /opt/intel/oneapi/mkl/2022.1.0/env/vars.sh
-rwxr-xr-x 1 root root 11614 Mar 11 10:41 /opt/intel/oneapi/mkl/latest/env/vars.sh
-rw-r--r-- 1 root root 7621 Feb 28 02:46 /opt/intel/oneapi/mpi/2021.6.0/env/vars.sh
-rw-r--r-- 1 root root 7621 Feb 28 02:46 /opt/intel/oneapi/mpi/latest/env/vars.sh
-rw-r--r-- 1 root root 6894 Jan 24 2022 /opt/intel/oneapi/tbb/2021.6.0/env/vars.sh
-rw-r--r-- 1 root root 6894 Jan 24 2022 /opt/intel/oneapi/tbb/latest/env/vars.sh
-rwxr-xr-x 1 root root 8497 Mar 18 01:15 /opt/intel/oneapi/vpl/2022.1.0/env/vars.sh
-rwxr-xr-x 1 root root 8497 Mar 18 01:15 /opt/intel/oneapi/vpl/latest/env/vars.sh
-rwxr-xr-x 1 root root 2603 Mar 29 02:07 /opt/intel/oneapi/vtune/2022.3.0/env/vars.sh
-rwxr-xr-x 1 root root 2603 Mar 29 02:07 /opt/intel/oneapi/vtune/latest/env/vars.sh
sorry for the delay in reponse.
ok, the alias for 'ls' has to go - get rid of it. setvars.sh uses 'ls' and expects it to be unaliased so it can find and run all the vars.sh files. if it's aliased in your .bashrc or other dot file, comment that out. if not maybe it's coming from default in /etc/profile or /etc/bashrc.
next, dash is not what I see for /bin/sh. I see bash
more /etc/lsb-release
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=20.04
DISTRIB_CODENAME=focal
DISTRIB_DESCRIPTION="Ubuntu 20.04.4 LTS"
rwgreen@orcsle156:~$ which bash
/usr/bin/bash
rwgreen:~$ ls -l /bin/sh
there is a discussion of bash vs dash for Ubuntu HERE
it's odd that my Ubu 20 system has /bin/sh linked to bash, not dash. my system gets kicked around a lot supporting issues. yours is probably more "pure" Ubuntu. I don't think that link matters. I really think it's the alias on 'ls'. Let me try that alias and see what I get.
$ alias
:: ccl -- latest
:: clck -- latest
:: dal -- latest
:: dnnl -- latest
:: dpl -- latest
:: ipp -- latest
:: ippcp -- latest
:: ipp -- latest
:: itac -- latest
:: mkl -- latest
:: mpi -- latest
:: tbb -- latest
:: vtune -- latest
sudo bash
first line, change
/bin/sh
to
/bin/sh -x
