Error stop is not working
Ben3
Sorry if this is a duplicate post, I haven't worked out how to search on the new forum layout.
It appears that the "error stop" statement only affects the image on which it was called, and doesn't cause the termination of other images. Consider this code:
program test
  if (this_image() == 1) write(*, *) num_images()
  if (this_image() == 1) error stop
  write(*, *) this_image(), "Might be printed..."
  sync all
  write(*, *) "Shouldn't be printed..."
end program test
I would expect it to only print the number of images once, and maybe print the maybe line on some of the images, and then terminate (the error stop would interrupt the sync all). Instead, I get this output:
 8
 2 Might be printed...
 4 Might be printed...
 8 Might be printed...
 6 Might be printed...
 7 Might be printed...
 5 Might be printed...
 3 Might be printed...
at which point it hangs until I ctrl+c it. I'm not sure what's going on. It happend in both Debug and Release mode builds (with/without optimisation). Here's my compiler version:
Compiling with Intel(R) Visual Fortran Compiler XE 12.1.5.344 [Intel(R) 64]...
Ben
jimdempseyatthecove
What happens if you use: SYNC ALL(STAT=iStat, ERRMSG=aCharVariableForMessage) Check (and report back) the return values. Jim Dempsey
Anonymous66
Valued Contributor I
Hi Ben, I have escalated this issue to the developers. The issue number is DPD200237069. I will post any updates I receive to this thread. Regards, Annalee Intel Developer Support
Ben3
Thanks Jim, Annalee.
I tried your suggestion, replacing the sync and write with
[fortran]
sync all (stat=istat, errmsg=imsg)
write(*, *) this_image(), istat, imsg
[/fortran]
This is what I get:
[plain]
 8
 2 0
 6 0
 3 0
 7 0
 5 0
 8 0
 4 0
[/plain]
The message is a blank string.
Cheers,
Ben
jimdempseyatthecove
Ben, Also notice that your output is as expected. i.e. The "Shouldn't be printed..." are not printed. Jim Dempsey
Ben3
Hi Jim, Sorry, I should have said that I replaced that write statement with the one printing the status from the sync all. So that line shouldn't have been printed either, because it's after the sync all. It's not printed by the first image, though, the one with the error stop statement (which is expected). Ben
