Here is another strange error I am getting when I add the CONTIGUOUS flag to a dummy argument in a recursive subroutine.
If I add to ExpressionParser.f the following line of code (its on line 129)
CONTIGUOUS:: NML
causes
gwf2bas7_OWHM.fpp to crash (it does call the function on line 2889) which has
RMLT(:,:,M)=EqnEval(LINE,MLTNAM(:M-1),RMLT(:,:,:M-1), !MODULE ExpressionParser WHICH CALCULATES EXPRESSION FROM STRING
+ .TRUE.,.TRUE.)
The error message I get is:
Error 21 Compilation Aborted (code 1) C:\~\gwf2bas7_OWHM.fpp 1
and
C:\~\gwf2bas7_OWHM.fpp: catastrophic error: **Internal compiler error: internal abort** Please report this error along with the circumstances in which it occurred in a Software Problem Report. Note: File and line given may not be explicit cause of this error.
compilation aborted for C:\~\gwf2bas7_OWHM.fpp (code 1)
I reattached the same project with the previous problem fixed, but includes only the one added statement that causes the crash.
Thanks. I moved this to its own thread since it's a separate problem and it will be easier to track it. Looking at this now.
I was able to cut this down a lot and sent it on to the developers as issue DPD200415576. Interestingly, my cut-down version was sensitive to bounds checking being enabled, but turning that off on your original project has no effect.
