Trying to compile the following code with Intel Fortran Composer 17.0.0 results in a catastrophic internal compiler error.
module nrtype use iso_fortran_env implicit none integer, parameter :: itp = int8 ! Define quarter precision integer(1 bytes). integer, parameter :: ihp = int16! Define half precision integer(2 bytes). integer, parameter :: isp = int32! Define single precision integer(4 bytes). integer, parameter :: idp = int64! Define double precision integer(8 bytes) integer, parameter :: rsp = real32 ! Define single precision real ( 4 bytes). 7.22 decimal digits integer, parameter :: rdp = real64 ! Define double precision real ( 8 bytes). 14.95 decimal digits integer, parameter :: rqp = real128 ! Define quad precision real (16 bytes). 34.02 decimal digits end module nrtype module modMesh use nrtype implicit none type DOFType(nEQs) integer(isp), len :: nEQs real(rdp) :: x real(rdp), dimension(nEQs) :: u, f, r real(rdp), dimension(nEQs,nEQs) :: fluxJac end type DOFType type cellType(nDOFs, nEQs) integer(isp), len :: nDOFs integer(isp), len :: nEQs integer(isp), dimension(2) :: idFace integer(isp), dimension(2) :: idNb type( DOFType(nEQs) ), dimension(nDOFs) :: DOF end type cellType type faceType(nDOFs, nEQs) integer(isp), len :: nDOFs integer(isp), len :: nEQs real(rdp) :: x integer(isp), dimension(2) :: idNb type( cellType(nDOFs, nEQs) ), pointer :: nbL, nbR end type faceType type meshType(nCells, nGhosts, nDOFs, nEQs) integer(isp), len :: nCells integer(isp), len :: nGhosts integer(isp), len :: nDOFs integer(isp), len :: nEQs integer(isp) :: nFaces type( faceType(nDOFs, nEQs) ), dimension(1-nGhosts:nCells+nGhosts) :: faceList type( cellType(nDOFs, nEQs) ), dimension(1-nGhosts:nCells+nGhosts) :: cellList end type meshType type( meshType(nCells=:, nGhosts=:, nDOFs=:, nEQs=:) ), target, allocatable :: mesh end module modMesh program test use nrtype use modMesh allocate ( meshType(5,5,1,1) :: mesh ) mesh%cellList(-4)%DOF(1)%u(1) = 1.0 end program test
Replacing lines 50 and 51 for
type( faceType(nDOFs, nEQs) ), dimension(-nGhosts:nCells+nGhosts) :: faceList type( cellType(nDOFs, nEQs) ), dimension(-nGhosts:nCells+nGhosts) :: cellList
prevents the compiler error but causes a segfault during execution.
What compiler options are you using? I haven't been able to make it fail yet.
I was compiling without any flag but you are right it stopped crashing here also, i don't know what could have changed. But still i get segfaults for both versions of the code.
I can reproduce the segfault and have escalated it as issue DPD200414994. If you manage to see the internal compiler error again, please let us know the details.
Topic Options
