28176 Discussions
Exclamation marks as a comment - blue/white bar
stedwomas
I am debugging a piece of code and I commented out some lines BUT some parts of the code have a blue /white  bar down the left hand side of the code . I save the subroutine and it compiles and builds ok , but the program  ignores the ( blue/white)  commented-out lines and in debug just ignores them and carries out the function of that line as if the exclamation is not there
Any  explanation
steve
Steve_Lionel
Black Belt Retired Employee
I have never seen that particular indication before. I am confused by your description - do the commented-out lines execute or not?
I can see a green bar indicating a "Saved Change" in the editor and debugger. What do you see if you position the mouse on one of those bars (don't click) and wait for a tooltip to pop up?
jimdempseyatthecove
Black Belt
What I find odd are three things:
1) you have a mixture of Fixed-Format comment (C in column 1) and Free-Format (! anywhere on line), yet the compiler did not complain.
2) The blue (striped) lines appears on only one set of commented out lines. Was there anything different as to how the comments were made.
3) The vertical blue line seems to be indented further to the right of the grey border than where the green and yellow vertical bar appears.
Would you happen to have non-printing characters on those lines?
Jim Dempsey
JohnNichols
Valued Contributor III
You cannot mix C and ! in the same file, you get this error.
When you add lines you get the yellow box down the left hand side.
Not sure about the blue, but it does not matter to you use a consistent commenting style.
Steve_Lionel
There's no problem in ifort using ! as a comment introducer in fixed-form source. I do this all the time (in working with code from others - I never write fixed-form myself.)
The errors reported in @JohnNichols ' compile aren't related to comment introducers.  What I see is the lack of an include file, errors because types haven't been declared. I can't see what caused the syntax error, as this is an excerpt.
D:\Projects>type t.for
      program main
      print *, "Hello World"
!C Test
      print *, "Bye World"
      end
D:\Projects>ifort -c t.for
Intel(R) Fortran Intel(R) 64 Compiler Classic for applications running on Intel(R) 64, Version 2021.7.1 Build 20221019_000000
Copyright (C) 1985-2022 Intel Corporation.  All rights reserved.
D:\Projects>
JohnNichols
I was testing F90 - there is no file type on the original source shown.  I did not test fixed format, long time since I used it and when I strike it I prefer to change to free.
The missing include file is a problem with the latest installation of MKL on oneapi, I have put a note on the other forum.
The left hand side colour lines are telling you something about what you are currently editing, some times yellow bar and sometimes  green solid.  I looked for an explanation in the help file, but it eluded me.
The green says it does not like it.
The mkl.
With the latest install of the oneapi, the original directory structure is
The file is present in there.
The new directory structure is
no mkl file present and the latest holds
No mkl include file.
I have not checked the mkl forum this morning.
But in all likelihood the blue lines is an editing code, we just have to find the list of editing codes.
mic_esp96
@JohnNichols ,
it actually happened the same thing yesterday. Reopened my PC after a while, to run a test on a different machine than the one I usually use at work, go to compile, and.... "ifort" command not found.
I went to check, and noticed Intel oneAPI installed (how, and why, no clue about) a new version, but without any binary in it. So when setting up the environment which usually refers to the "latest" symlink, then all the tools where missing.
Made a clean install of the new 2022.3.1 release, and removed previous versions.
Yet curious why that happened though.
Steve_Lionel
In a free-form file, C is not a comment introducer.
FortranFan
Any  explanation
steve
@stedwomas ,
Re: "the program  ignores the ( blue/white)  commented-out lines," what program is it?  Is it really Microsoft Visual Studio with which Intel software product provides an integration in conjunction with the Intel Fortran compiler(s) also. or is this "program" some other IDE / editor?  Can you confirm?  Because the behavior with "blue /white  bar down the left hand side of the code" does NOT appear to be with Visual Studio and Intel Fortran integration.
JohnNichols
There is no color coded text as you see in the screen shots I put up, wonder which IDE it is?  Good call.
Humour for the day:
Not sure what happened on the install for the latest HPC.
JohnNichols
Just updated and the mkl latest folder looks normal and the program runs, was there something wrong with the mkl on the second last update.
stedwomas
Sorry ben away for a few days and thank you all for your interest - the comment on the "blue /white  bar" lines is just ignored - it was the last item I modified. I saved everything - the comment is  just ignored as though the comment does not exist - I hvent a clue what the  "blue /white  bar" is
stedwomas
The blue/white lines mean modified code from the  last check in . Gone a bit further and the debugging seems to have a mind of its own - trundling through the code, doesn't obey breakpoints , the breakpoints I put bin end up on comment lines and when you debug  putting a "F10"- the pointer skips lines. I think there is corruption in the code somewhere and the compiler has not picked it up.
jimdempseyatthecove
Black Belt
Are you using the/a preprocessor?
Are you debugging optimized code?
Jim Dempsey
