Expected behavior of type-bound operators
Emil_S_
Hi
If I compile the following code with ifort 14.0.3
module abmod
  implicit none
  type :: a
     integer :: value
   contains
     procedure :: assign => a_assign
     generic :: assignment(=) => assign
  end type a
  type, extends(a) :: b
   contains
     procedure :: assign => b_assign
  end type b
contains
  subroutine a_assign(this, value)
    implicit none
    class(a), intent(out) :: this
    integer, intent(in) :: value
    print *, "I am a_assign!"
    this%value=value
  end subroutine a_assign
  subroutine b_assign(this, value)
    implicit none
    class(b), intent(out) :: this
    print *, "I am b_assign!"
    this%value=value
  end subroutine b_assign
end module abmod
program test
  use abmod
  implicit none
  class(a), allocatable :: aclass
  class(b), allocatable :: bclass
  allocate(b::aclass)
  allocate(bclass)
  aclass=1
  bclass=1
end program test
And run the program, I get
$ ifort -g -o test test.f90
$ ./test
I am a_assign!
I am a_assign!
Is this the expected behavior? I had expected that the b_assign procedure would have been called in both cases, due to the dynamic type being class b. I see similar behavior with the other operators.
If I use gfortran 4.6, 4.7 or 4.9, the b_assign procedure is called. However gfortran 4.8 shows similar behavior as ifort 14.0.3
Best regards
Emil Sørensen
Izaak_Beekman
New Contributor II
This behavior from ifort doesn’t make sense to me, I would expect assign_b to be called as well. Haven’t had time to dig through the standard yet, however.
Kevin_D_Intel
I also see the same reported behavior with our current Beta. I reported this to Development (see internal tracking id below) to get their assessment and will keep you updated on what I hear.
(Internal tracking id: DPD200358171)
(Resolution Update on 09/12/2015): This defect is fixed in the Intel® Parallel Studio XE 2016 Release (2016.0.109 - Linux)
Kevin_D_Intel
I confirmed the associated fix for this issue in the Intel® Parallel Studio XE 2016 Release (Version 16.0.0.109 Build 20150815) available from the Intel® Software Development Products Registration Center (IRC).
