Dear Sir/Madam,
I would like to know whether can I extract data from f90sql using java? If yes what should i need to do please suggest me. Thanks in advance.
Neha
The natural way of connecting to a database and running queries in a Java application is to use JDBC. Why do you want to use F90SQL, which is intended for connecting Fortran programs to a database, instead?
As far as I know, JDBC is far more widely used and supported than F90SQL, and F90SQL requires that you have ODBC drivers deployed. Which database do you propose to connect to?
