FORMAT
brunocalado
[cpp]10 FORMAT(1000(L1))[/cpp]
I need to create a where I can change the 1000 for a Integer variable, which I can modify during the execution. How can I do this?
TimP
Quoting - brunocalado
This is a standard FAQ thing.
1) Under standard Fortran 77, you can use internal write to create a format string which does what you want.
2) ifort supports the DEC vms Fortran "VFE" extension
3) Fortran 2008 addresses this topic
You are chronically short on efforts to look up answers to your questions so as to refine them to something which could be discussed usefully.
