I try to make a posting with a 15 k zip-file as attachment and I fail again and again. After clicking on Attach Files and Post Message nothing happens. What's going wrong?
Muppets
P.S. It is very urgent to me to make the mentioned posting with the attachment ...
Muppets
This bug has been around from, I think, day 1. It seems that either length of the message or a timeout between starting typing and attaching triggers it -- usual workaround is to post a short followup with only the attachment.
As a test, I'll try to post a followup with a long timeout and a small zip file. (If you see it, it means I didn't succeed to trigger it).
Jugoslav
Jugoslav
Test
I managed to reproduce it -- the original test message, which you haven't seen, was rather long -- it was 2-3 kB long. Attachment of a file failed (the button just does noting). When I shortened the message body, it passed through.
Thank you, so I will post two messages.
