I am not familiar with opening a file with form set to Unformated with Acess set to Stream. Is this identical to opening a file with form set to Binary. If not, since they are record free files would something written with both forms produce the same binary? What would be the pros/cons between them if there is a difference. Right now I am able to postprocess form set to binary with python, but I assume it should work with stream because its equivalent to a C-binary?
Thanks as always.
Yes, it's the same (for unformatted). 'BINARY' is an extension, ACCESS='STREAM' is standard.
So
[fortran]
Open(UNIT=55,FORM='unformatted',ACCESS='STREAM')
[/fortran]
would produce the same file as:
[fortran]
Open(UNIT=55,FORM='BINARY')
[/fortran]
Assuming all the WRITEs are the same, yes.
