Floor Function
JohnNichols
Honored Contributor I
write(*,300)count,SUMDW1,floor(STRNS),CGT,YB-CGT,CGTLMT
the third element of the write statement prints as 0.00 instead of 30.00. STRNS has a value of 30.9
If I pull it out and set a variable first it prints as normal.  Is this expected?
jimdempseyatthecove
You will have to show the 300 FORMAT statement to make sense out of the behavior.
Jim
JohnNichols
300 Format("                                  ",i2,"    ",F6.0,"        ",F3.0,"    ",F6.2,"    ",F6.2,"     ",F6.2)
JohnNichols
Floor function returns an integer,  I should have checked.
jimdempseyatthecove
Yes. So either change F3.0 to I3 or use
write(*,300)count,SUMDW1,real(floor(STRNS)),CGT,YB-CGT,CGTLMT
Jim Dempsey
