29258 Discussions
Formatted OPEN don't work in Linux?
likeuclinux
Here is my code, work in windows but not in linux:
program circle
CHARACTER*1 A
INTEGER IOS
OPEN(UNIT = 789,
& FILE= 'charlie.dem',
& FORM = 'FORMATTED',
& ACCESS = 'DIRECT',
& RECL = 1,
& STATUS = 'OLD',
& ERR = 93)
READ(789, REC = 1) A
READ(789, REC = 3, IOSTAT=IOS) A
write (*,*) 'IOS=',IOS,' A=',A
93 write (*,*) 'you have passed...'
stop
end
The file charlie.dem is normal text file you can create by youself.
But in linux I get following error:
forrtl: severe (257): formatted I/O to unit open for unformatted transfers, unit 789, file /home/rong/carmenrt_building/aermap/430/charlie.dem
Image PC Routine Line Source
debugme 080948AF Unknown Unknown Unknown
debugme 08093ECF Unknown Unknown Unknown
debugme 08076F76 Unknown Unknown Unknown
debugme 08069C92 Unknown Unknown Unknown
debugme 0806992D Unknown Unknown Unknown
debugme 080533EA Unknown Unknown Unknown
debugme 08049C3C Unknown Unknown Unknown
debugme 08049B31 Unknown Unknown Unknown
libc.so.6 00740AD4 Unknown Unknown Unknown
debugme 08049A61 Unknown&n bsp; Unknown Unknown
Build this program using: ifort -o debug.exe debug.for.
Please help!!!
Steven_L_Intel1
The error message is backwards - it should say "unformatted I/O to unit open for formatted transfers". You opened unit 789 FORMATTED but are doing unformatted READs from it. Can't do that. My suggestion is that you probably wanted the OPEN to say UNFORMATTED.
Steven_L_Intel1
By the way, it doesn't work on Windows either.
likeuclinux
Thanks, I solve this in Linux by:
  program circle
CHARACTER*1 A
INTEGER IOS
OPEN(UNIT = 789,
& RECL = 1,
& STATUS = 'OLD',
& ERR = 93)
READ(789, 6, REC = 1) A
6 format(a1) ---- specify format
READ(789, 7, REC = 3, IOSTAT=IOS) A
7 format(a1) ----- specify format
stop
end
But the old code do work in windows, I build with compaq virtual fortran 6.6, here it is output
in windows:
D:aermap_testcase430 un>circle.exe
IOS= 0 A=c
you have passed...
Steven_L_Intel1
Ok. It does not work using Intel Fortran on Windows.
likeuclinux
Maybe that means inter-compiler is more strong-typed than microsoft compiler...:)
