I am moving over to a 64 bit environment and have installed vs2005 and applied sp1 and sp1 for vista.
This system runs windows vista home premium 64 bit.
I then tried installing w_fc_c_10.0.027_intel64.exe
Trying to start the compiler from a dos prompt i get
Intel Fortran Compiler for applications running on Intel 64, Version 10.0.
027
Copyright (C) 1985-2007 Intel Corporation. All rights reserved.
The specified configuration type is missing. The tools for the
configuration might not be installed.
C:Windowssystem32>
when trying from vs i get an error message about ifort not found. i've uninstalled all intel entries and reinstalled and get the same messages. i had seen a post about selecting options at install time. i did not see get these options.
any thoughts?
ian chivers
a simple c++ program (classic hello world) needless to say compiles and runs from within vs2005.
By the way, I started to answer about Itanium, since you put ia64 in the title. I've seen plenty of questions "why doesn't Itanium compiler work on AMD?" Maybe if enough customers tell Intel marketing that meaningful terminology for x86-64 platforms would be OK, the confusion might be reduced.
