29278 Discussions
Fortran 9.0 Windows with Studio .NET
tdigital1
Please I have a problem:
1. I'm using Fotran Windows 9.0 standard.
It's "OK" with command line . I ran the file int_sin.f90 ( docs/samples) .
2. Now I'm trying to use Visual Studio .net ( version 2003) .
I read the "getting started with the Intel Visual Fortran Compiler 9.0 for Windows".
* Steps
* Create a project ==> ok
* Select Application Settings and Select Empty project ==> ok
* Select File - Add exisiting item ( int_sin.f90) ==> ok
* Appears the program ==> ok
* Build -clean solution ==> ok
*** Now it's a problem ***
* Build - Build Solution
does not appear the message "Compiling with Intel Fortran 9.0 ...." and don't generate
the .exe
somebody has some idea of this problem..
Alfredo
Did you chose "Intel Fortran Projects" and "Console Application"? If you chose some sort of C++ project, you'll get that behavior.
Do you see the blue Intel Fortran F logo when starting VS.NET? Do you get a line output that says "Build log written to ..."? If so, click on the link given and post the contents here.
tdigital1
Dear Steve
Answer ==> Yes.
This message appears:
------ Build started: Project: int_sin_fort, Configuration: Debug|Win32 ------
Deleting intermediate files and output files for project 'int_sin_fort', configuration 'Debug|Win32'.
int_sin_fort build succeeded.
( .exe is not generated)
Thanks again,
Alfredo
Please report this to Intel Premier Support and attach a ZIP file of the project. We'll need to see what's going on.
