Fortran 9.1
kurt_hall
I am needing Fortran 9.1 to work with Abaqus. I was told after I bought 10.1 I could download old versions of Fortran. I have not been able to find this site. Could you help?
Kurt Hall
Go to the Intel Registration Center and register your serial number, if you have not done so already. Log in to the registration center and select the product you registered. Somewhere around the middle of the page you'll see "Select other packages from the dropdown menu". To the right of that is a dropdown menu that defaults to 10.1, but you can select 9.1 and, once it refreshes, select the update version you want.
kurt_hall
Thanks a bunch!!
Kurt Hall
