29627 Discussions
Fortran Compiler Undefined Reference to Main
Michael_A_3
Hello All,
I am trying to compile CP2K using the Intel(R) Fortran 64 Compiler XE compiler. To optimize my code I have been playing with some of the compilation flags. When I add the flags
-xSSE2 -no-ipo -fpp -free
My compilation fails with an error
/cm/shared/apps/intel/composer_xe_2013_sp1.2.144/compiler/lib/intel64/for_main.o: In function `main':
/export/users/nbtester/efi2linux_nightly/branch-14_0/20140121_010000/libdev/frtl/src/libfor/for_main.c:(.text+0x42): undefined reference to `MAIN__'
make[3]: *** [/home/agiorm/cp2k-2.6.2/exe/komodonotracebackfast/dbcsr_example_1.popt] Error 1
I looked up the main file it listed but it was a simple binary file.
Has anyone seen this type of behavior before and would have a suggestion on how to fix it?
If you are compiling a single source and not building an executable application, add -c for "compile only". Otherwise it will try to link an executable.
If the main program is not in Fortran, then add -nofor-main to the ifort command that does the link.
