29642 Discussions
Fortran DLL called from do loop does not work OK second time
Reinaldo
Hi:
I am integrating a fortran DLL with a fortran main program.
The DLL is a subroutine that calls several other subroutines. The DLL sub is called a number of times within a do loop in the main program.
The first time the DLL sub is called it works apparently OK. Howrver the second time it does not work ok. For example the second time this piece of code is called it does not correctly assing the pointer variables.
SUBROUTINE SGWF2BAS7PNT(IGRID)
C Change global data to a different grid.
USE GLOBAL
USE PARAMMODULE
USE GWFBASMODULE
NCOL=>GLOBALDAT(IGRID)%NCOL
NROW=>GLOBALDAT(IGRID)%NROW
NLAY=>GLOBALDAT(IGRID)%NLAY
Any idea?
Reinaldo
DavidWhite
Valued Contributor II
Reinaldo,
I think we need to see some more of the code associated with the call and the variables involved.
Can you post a more complete code example?
David
