Fortran DLM question
postaquestion
I am using ver 10.0 (build 26) of Intel Fortran. I can run the application (which uses the Fortran DLM) on a machine which has Visual Studio 2005 and Fortran Compiler. However when I try to run the application on a clean virtual machine (after copying the relevent Intel DLLs in the respective folders - which I found using Dependency Walker), the application fails while loading the DLM, saying DLM not found.
I appreciate your help in resolving this issue. Many thanks.
I am not entirely certain what you mean by DLM, but I think you really mean DLL here. You will also need the MSVC 2005 redistributables installed.
