I recently upgraded to Intel Visual Fortran Compiler XE 12.0.5.221 [IA-32] and use VS2008 as IDE under Windows XP SP3 home Edition.
For some reason the Fortran documentation is not available from the Microsoft Document Explorer. I tried repair/reinstall IVF, then repair/reinstall VS2008 and again repair/reinstall IVF and also running RepairVS08Integration.exe. Obviously without the desired result. The integration of the compiler is OK, it is just the documentation that fails.
Any ideas?
Walter Kramer
Any ideas?
Walter Kramer
链接已复制
7 回复数
Please open a command prompt and try the following:
1. CD to\help
2. Enter the following commands, in order:
[plain]
H2Reg.exe -r CmdFile=..\Documentation\vshelp\1033\intel.forprodocs\H2Reg_cmd.ini
H2Reg.exe -r CmdFile=..\Documentation\vshelp\1033\intel.fprocompilerdocs\H2Reg_cmd.ini
[/plain]
Let me know if this helps.
