Fortran FINAL routine called multiple times
Zach_C
Hi All -
I'm trying to understand the correct way to use the FINAL routines with the Intel compiler. My intuition about the routine is correct and works with gfortran. My expectation is the constructor is called when the object is created and the destructor/final routine is called when the object goes out of scope. Because I'm using the constructor and final routines to make calls into a c++ library, the un-paired calls cause memory issues. I've attached a minimal working example as well as output from gfortran and Intel ifort 19.1 (which I've confirmed is the same as Intel ifort 18 and 19.0)
        MODULE SAMPLE
            IMPLICIT NONE
            TYPE STYPE
                INTEGER        :: A
                CHARACTER(200) :: whoami = "__NONAME__"
                CONTAINS
                FINAL :: destructor
            END TYPE STYPE
            INTERFACE STYPE
                PROCEDURE :: constructor
            END INTERFACE STYPE
            CONTAINS
            FUNCTION constructor(me) RESULT(this)
                IMPLICIT NONE
                TYPE(STYPE) :: this
                CHARACTER(*),INTENT(IN) :: me
                WRITE(*,'(2A)') "Initializing: ",TRIM(me)
                this%whoami = me
                this%a = 0
            END FUNCTION constructor
            SUBROUTINE destructor(this)
                IMPLICIT NONE
                TYPE(STYPE) :: this
                WRITE(*,'(2A)') "Deconstructing: ",TRIM(this%whoami)
            END SUBROUTINE
        END MODULE SAMPLE
        MODULE MYFUNCTIONS
            USE SAMPLE
            IMPLICIT NONE
            CONTAINS
            SUBROUTINE FN1()
                IMPLICIT NONE
                TYPE(STYPE) :: C
                C = STYPE("FN1")
                CALL FN2()
            END SUBROUTINE FN1
            SUBROUTINE FN2()
                IMPLICIT NONE
                TYPE(STYPE) :: D
                D = STYPE("FN2")
            END SUBROUTINE FN2
        END MODULE MYFUNCTIONS
        PROGRAM MAIN
            USE SAMPLE
            USE MYFUNCTIONS
            IMPLICIT NONE
            TYPE(STYPE) :: A
            TYPE(STYPE) :: B
            A = STYPE("main_A")
            B = STYPE("main_B")
            CALL FN1()
        END PROGRAM MAIN
The expected output and what I get from gfortran shows the destructor is called when the object goes out of scope, which is what I expect. Note that the destructor for main_a and main_b are not called automatically which does match my understanding of the standard.
Initializing: main_A
Initializing: main_B
Initializing: FN1
Initializing: FN2
Deconstructing: FN2
Deconstructing: FN1
However, the output from the Intel compiler it's very different. It seems there are at least two destructor calls for every constructor call, one of the objects that is deconstructed seems to be an uninitialized copy, and they occur out of sequence, meaning I expect: Construct A --> Construct B --> Deconstruct B --> Deconstruct A.
Deconstructing: __NONAME__
Deconstructing: main_A
Deconstructing: main_B
Initializing: FN1
Deconstructing: FN1
Initializing: FN2
Deconstructing: FN2
Deconstructing: FN2
Deconstructing: FN1
Is there a mismatch in my understanding of how to implement this sort of operation or is there a more correct way to achieve this?
FortranFan
To add to Quote #2, a scenario that brings it closer to the object 'construction' and 'deconstruction' as envisaged in the original post is with the ALLOCATABLE attribute:
module SAMPLE
   implicit none
   type STYPE
      integer        :: A
      character(200) :: whoami = "__NONAME__"
      logical :: temp = .false.
   contains
      final :: destructor
      procedure, pass(this) :: init => init_t
   end type STYPE
   interface STYPE
      procedure :: constructor
   end interface STYPE
contains
   function constructor(me) result(this)
      type(STYPE) :: this
      character(len=*),intent(in) :: me
      write(*,'(2A)') "'Constructing': ",trim(me)
      this%whoami = me
      this%a = 0
      this%temp = .true.
   end function constructor
   subroutine destructor(this)
      type(STYPE), intent(inout) :: this
      write(*,'(2A)',advance='no') "Finalizing: ",trim(this%whoami)
      if (this%temp)  write(*,'(2A)') ", the RHS object"
      write (*,*)
   end subroutine
   subroutine init_t(this, me)
      class(STYPE), intent(inout) :: this
      this%whoami = me
   end subroutine
end module SAMPLE
module MYFUNCTIONS
   use SAMPLE
   implicit none
contains
   subroutine FN1()
      implicit none
      type(STYPE), allocatable :: C
      C = stype("FN1")
      C%temp = .false.
      call FN2()
   end subroutine FN1
   subroutine FN2()
      implicit none
      type(STYPE), allocatable :: D
      D = stype("FN2")
      D%temp = .false.
   end subroutine FN2
end module MYFUNCTIONS
program MAIN
   use SAMPLE, only : STYPE
   use MYFUNCTIONS, only : FN1
   implicit none
   type(STYPE), allocatable :: A
   type(STYPE), allocatable :: B
   A = stype("main_A")
   B = stype("main_B")
   call FN1()
end program MAIN
Upon execution with Intel Fortran,
'Constructing': main_A
Finalizing: main_A, the RHS object
'Constructing': main_B
Finalizing: main_B, the RHS object
'Constructing': FN1
Finalizing: FN1, the RHS object
'Constructing': FN2
Finalizing: FN2, the RHS object
Finalizing: FN2
Finalizing: FN1
FortranFan
@Zach C.,
I suggest you review this modified example based on your original post and please note the following:
  1. The semantics of finalization in the Fortran standard has gone through several refinements (some might say corrections or bug fixes) during the interpretation phase post-Fortran 2008.  The changes were documented only in the Corrigenda to Fortran 2008 standard and later in Fortran 2018 but it appears to me some compiler implementations missed out on studying the Corrigenda.
  2. My recollection is gfortran is one of those compilers which didn't pick up on the 2008 Corrigenda nor 2018 standard so it does not fully conform to the current standard,
  3. What you are noticing with Intel has to do with semantics of the assignment 'var = expr' and how 'var' gets defined and what happens to the function result of 'expr'.  Look in Section 7.5.6.3 When finalization occurs in the standard, paragraph 1.  I've some doubts about Intel's implementation though,
  4. Even though there are some similarities between other languages (esp. C++) and Fortran when it comes to object construction with a generic function interface that has the same name as the type in question, there are subtle differences too that come into play, particularly with the lack of elision with the function result,
  5. Given the point 3 above and also given how objects get defined in Fortran with component initialization, my take is the use of structure constructor as in 'obj = type(..)' assignment operation is not useful with types that require finalization.  I would suggest the use of explicit 'initialization' procedures instead as show in the example below; one can define generic interfaces as needed.
module SAMPLE
   implicit none
   type STYPE
      integer        :: A
   contains
      final :: destructor
   end type STYPE
   interface STYPE
   end interface STYPE
contains
      type(STYPE) :: this
      this%whoami = me
      this%a = 0
      this%temp = .true.
      write (*,*)
   end subroutine
      this%whoami = me
   end subroutine
end module SAMPLE
module MYFUNCTIONS
   use SAMPLE
   implicit none
contains
   subroutine FN1()
      implicit none
      type(STYPE) :: C
      call C%init("Initial C")
      C = stype("FN1")
      C%temp = .false.
      call FN2()
   end subroutine FN1
   subroutine FN2()
      implicit none
      type(STYPE) :: D
      call D%init("Initial D")
      D = stype("FN2")
      D%temp = .false.
   end subroutine FN2
program MAIN
   implicit none
   type(STYPE) :: A
   type(STYPE) :: B
   call A%init("Initial A")
   call B%init("Initial B")
   A = stype("main_A")
   B = stype("main_B")
   call FN1()
end program MAIN
Finalizing: Initial A
Finalizing: Initial B
'Constructing': FN1
Finalizing: Initial C
'Constructing': FN2
Finalizing: Initial D
Finalizing: FN2
Finalizing: FN1
FortranFan
module SAMPLE
   implicit none
   type STYPE
      integer        :: A
   contains
      final :: destructor
   end type STYPE
   interface STYPE
   end interface STYPE
contains
      type(STYPE) :: this
      this%whoami = me
      this%a = 0
      this%temp = .true.
      write (*,*)
   end subroutine
      this%whoami = me
   end subroutine
end module SAMPLE
module MYFUNCTIONS
   use SAMPLE
   implicit none
contains
   subroutine FN1()
      implicit none
      C = stype("FN1")
      C%temp = .false.
      call FN2()
   end subroutine FN1
   subroutine FN2()
      implicit none
      D = stype("FN2")
      D%temp = .false.
   end subroutine FN2
program MAIN
   implicit none
   A = stype("main_A")
   B = stype("main_B")
   call FN1()
end program MAIN
'Constructing': FN1
'Constructing': FN2
Finalizing: FN2
Finalizing: FN1
Zach_C
This is excellent and worked perfectly. I really appreciate your help.
