After electronic installation of the 'Intel Visual Studio Fortran_XE on my PC (Windows XP), when compiling my code in Release mode, it works, but in Debug mode I get the error:
"LINK : fatal error LNK2023: bad DLL or entry point 'msobj80.dll'"
I find one'msobj80.dll' that was installed in MSV 9.0 directory with same version : 9.0.21022.8 and date (11/7/2007) as the 'link.exe' in same directory.
There is another 'msobj80.dll'in 'Common Files' with same version 9.0.21022.8but different length (71ko / 86ko) and different date (11/8/2007). Exchanging these files does not work. What to do ?
Hello, I moved this thread to our Intel Visual Fortran Compiler for Windows forum, so that one of our technical consulting engineers can assist you.
Aubrey W.
Intel Software Network Support
Aubrey W.
The DLL should be in the Common7\IDE folder. Use the 9.0.21022.8 version.
I too have this error when compiling for debug in Visual Studio:
But I have Windows XP Pro x64 SP2 and Intel XE using 2008 (but for some reason Visual Studio 9.0 folders also exist).
Do I need to copy a file somewhere?
Visual Studio 2008 is Visual Studio 9.0. Follow the previous advice.
Both are called the 9.0.21022.8 version. :-)
I copied from
C:\Program Files (x86)\Common Files\Microsoft Shared\VSA\9.0\VsaEnv
msobj80.dll [11/08/2007 with 72,192 bytes]
to
C:\Program Files (x86)\Microsoft Visual Studio 9.0\Common7\IDE
(no existing msobj80.dll file)
and then the link worked.
I copied from
to
Right - the IDE folder is where that DLL belongs.
