All,
In my continuing journey in learning how to interoperate Fortran with C, I've come across yet another confusing situation. Below, I'm trying to pass two REAL data arrays to a C routine gpc _cvlist to populate a data structure with the data in the arrays but when I compile, I get the error #6633: The type of the actual argument differs from the type of the dummy argument. [XV] & [YV] . I'm not understanding why this error would occur since I (thought) was consistent with my declarations concerning the two arrays.
Below is the code:
! F2CGPCList.f90 ! ! FUNCTIONS: ! F2CGPCList - Entry point of console application. ! !**************************************************************************** ! ! PROGRAM: F2CGPCList ! ! PURPOSE: Entry point for the console application. ! !**************************************************************************** module gpc_list use, intrinsic :: ISO_C_BINDING implicit none private public C_GPC_VERTEX, C_GPC_VERTEX_LIST, C_GPC_POLYGON public gpc_cvlist TYPE, BIND(C) :: C_GPC_VERTEX REAL(C_DOUBLE) :: x REAL(C_DOUBLE) :: y END TYPE C_GPC_VERTEX TYPE, BIND(C) :: C_GPC_VERTEX_LIST INTEGER(C_INT) :: num_vertices TYPE(C_PTR) :: C_vertex END TYPE C_GPC_VERTEX_LIST TYPE, BIND(C) :: C_GPC_POLYGON integer(C_INT) num_contours type(C_PTR) hole type(C_PTR) C_contour END TYPE C_GPC_POLYGON interface !********************************************************************* ! GPC FUNCTION ADD-ONS ! SUBROUTINE gpc_cvlist(npoly, px, py, vertex_list, iret) & BIND(C,name='gpc_cvlist') IMPORT :: C_INT, C_FLOAT, C_GPC_VERTEX_LIST implicit none integer(C_INT), intent(inout) :: npoly integer(C_FLOAT), intent(inout) :: px(*) integer(C_FLOAT), intent(inout) :: py(*) TYPE(C_GPC_VERTEX_LIST) vertex_list integer(C_INT), intent(inout) :: iret end SUBROUTINE gpc_cvlist end interface end module gpc_list program F2CGPCList use GPC_List use, intrinsic :: ISO_C_BINDING implicit none ! Variables ! - - - local declarations - - - INTEGER :: nverts,ii,ier REAL :: xv(10),yv(10) type(C_GPC_VERTEX_LIST) C_verticies ! Body of F2CGPCList WRITE (*,*) "The following are the polygon points to be xfered " nverts = 10 DO ii = 1,nverts xv(ii) = float(ii*10) yv(ii) = float(ii*10+1) write(*,*)'x/yv = ',ii,xv(ii),yv(ii) END DO CALL gpc_cvlist( nverts, xv, yv, C_verticies, ier ) end program F2CGPCList
#include "gpc.h" #define G_MALLOC(p,type,np,str) { if ((np) > 0) { \ (p)=(type*)malloc((np)*sizeof(type)); \ if (p==((type*)NULL)) { \ fprintf(stderr, "malloc failure: %s\n", (str) ); \ } \ } \ else \ (p)=(type*)NULL; \ } void gpc_cvlist ( int npoly, float *px, float *py, gpc_vertex_list *contour, int *iret ) /************************************************************************ * gpc_cvlist * * * * This function generates a GPC vertex list structure given a set of * * polygon points. * * * * gpc_cvlist ( npoly, px, py, contour, iret ) * * * * Input parameters: * * *npoly int Number of points in polygon * * *px float[] X array * * *py float[] Y array * * * * Output parameters: * * *contour gpc_vertex_list Vertex list structure * * *iret int Return code * * * ** * ***********************************************************************/ { int ii; /*---------------------------------------------------------------------*/ *iret = 0; contour->num_vertices = npoly; G_MALLOC ( contour->vertex, gpc_vertex, npoly, "gpc_vertex creation" ); for ( ii = 0; ii < npoly; ii++ ) { contour->vertex[ii].x = px[ii]; contour->vertex[ii].y = py[ii]; } return; }
Thanks in advance,
Jeff
Good grief...never mind. Just saw my error:
should be
real(C_FLOAT), intent(inout) :: px(*)
real(C_FLOAT), intent(inout) :: py(*)
however...now it is complaining with a linker error:
1>F2C-GPCList.obj : error LNK2019: unresolved external symbol _gpc_cvlist referenced in function _MAIN__
gpc_cvlist is in the C portion of the project so the compiler should see it...
Is your C code in a file with type .cpp? If so, you need 'extern "C"' in front of the routine declaration.
