Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Fortran linking error to C functions upgrading from 32 to 64 bit
I have the following two sample C functions: void rsub(...) and int sfunc(...)
Contents of rsub.c:
#include    "stdlib.h"
#include    "stdio.h"
void rsub(int iscalar, int icount){
    int        i;
    int        sum;
    printf("now in rsub()\n");
    printf("iscalar   =%d\n", iscalar);
    printf("icount    =%d\n", icount);
    sum = iscalar;
    sum += icount;
    printf("sum       =%d\n", sum);
    printf("leaving rsub()\n");
Contents of sfunc.c:
#include    "stdlib.h"
#include    "stdio.h"
int sfunc(int iscalar, int icount) {
    int        i;
    int        sum;
    printf("now in sfunc()\n");
    sum = iscalar;
    sum += icount;
    printf("leaving sfunc()\n");
    return(sum);
And they each have their respective FORTRAN interface modules:
contents of rlib_interface.for:
        MODULE rlib_interface
C       This  module specifies the FORTRAN interface for the S test.
        IMPLICIT NONE
        PRIVATE
        SAVE
C
          PUBLIC    rsub
C
        INTERFACE
C
            SUBROUTINE rsub( iscalar, icount )
                !DEC$ATTRIBUTES C, REFERENCE :: rsub
C
                INTENT( IN )              ::  iscalar
                INTENT( IN )              ::  icount
C
                INTEGER(KIND=4)           ::  iscalar
                !DEC$ATTRIBUTES VALUE     ::  iscalar
C
                INTEGER(KIND=4)           ::  icount
                !DEC$ATTRIBUTES VALUE     ::  icount
C
            END SUBROUTINE rsub
C
        END INTERFACE
C
        END MODULE rlib_interface
Contents of slib_interface.for:
       MODULE slib_interface
        IMPLICIT NONE
        PRIVATE
        SAVE
C
          PUBLIC    sfunc
C
        INTERFACE
C
            FUNCTION sfunc( iscalar, icount )
                !DEC$ATTRIBUTES C, ALIAS:'_sfunc' :: sfunc
C
                INTEGER(KIND=4)           ::  sfunc
C
C
C
C
            END FUNCTION sfunc
C
        END INTERFACE
C
        END MODULE slib_interface
And I call them from FORTRAN programs R and S:
Contents of r.for:
    PROGRAM R
C     Test building in 32-bit mode and in 64-bit mode
C
      USE RLIB_INTERFACE
      INTEGER K/5/
C
      WRITE(6,6005)
 6005 FORMAT('Expected message from RSUB is 7')
C
      CALL RSUB(K, 2)
      END
Contents of s.for:
      PROGRAM S
C
      USE SLIB_INTERFACE
      INTEGER K/5/
C
      WRITE(6,6005)
 6005 FORMAT('Expected return from SFUNC is 7')
C
      N = SFUNC(K, 2)
C
      WRITE(6,6010)N
 6010 FORMAT('N=',I12)
      END
I run a file I call devenv32.bat to set up my 32-bit C/Fortran build environment in a DOS command window:
Contents of devenv32.bat:
set VSDIR=C:\Program Files (x86)\Microsoft Visual Studio 11.0
call "%VSDIR%\VC\BIN\VCVARS32.BAT"
echo setting IntelFTNDIR
set IntelFTNDIR=C:\Program Files (x86)\Intel\Composer XE 2013 SP1
echo calling ifortvars.bat
call "%IntelFTNDIR%"\bin\ifortvars.bat ia32 vs2012
I run rcomp.bat to compile r:
ifort -c /module:. /integer-size:32 /real-size:32 rlib_interface.for
ifort -c /module:. /integer-size:32 /real-size:32 r.for
cl -c  rsub.c
I run rbuild.bat to build r:
ifort /exe:r r.obj ^
rsub.obj
And similarly for scomp.bat:
ifort -c /module:. /integer-size:32 /real-size:32 slib_interface.for
ifort -c /module:. /integer-size:32 /real-size:32 s.for
cl -c sfunc.c
...and sbuild.bat:
ifort /exe:s s.obj ^
sfunc.obj
And then I run r:
now in rsub()
iscalar   =5
icount    =2
sum       =7
leaving rsub()
And then I run s:
N=           7
now in sfunc()
iscalar   =5
icount    =2
leaving sfunc()
So far everything is exactly correct.
And then I start a new DOS window and attempt to shift gears to 64-bit compilation for both C and FORTRAN.
Contents of devenv64.bat:
call "%VSDIR%\VC\vcvarsall" x86_amd64
call "%IntelFTNDIR%"\bin\ifortvars.bat intel64 vs2012
R compiles, links, and runs great.
S however, having a function return type compiles, but then when I go to link in sbuild.bat I get the following error message:
C:\Users\ClarkBG\Desktop\Dexter\ToShip>ifort /exe:s s.obj sfunc.obj
Microsoft (R) Incremental Linker Version 11.00.61030.0
Copyright (C) Microsoft Corporation.  All rights reserved.
-out:s.exe
-subsystem:console
s.obj
sfunc.obj
s.obj : error LNK2019: unresolved external symbol _sfunc referenced in function MAIN__
s.exe : fatal error LNK1120: 1 unresolved externals
So...what's going on?
  • Both R and S work fine in my 32-bit C/Fortran compile/link/run DOS environment.
  • R works fine in 64-bit too.
  • S compiles, but won't link in 64-bit.
  • The only functional differences between programs R and S are:
    • rsub.c returns void and is CALLed as a FORTRAN subroutine.
    • sfunc.c has an int return type and is used in-line as a FORTRAN function.
Is there a work-around for this?  This is a tiny example of the same issue I'm having while maintaining a much larger proprietary commercial code.
Highlighted
Black Belt
Your Fortran code for the interface of sfunc explicitly sets the linker name of the procedure (its alias) to be `_sfunc`.  That name happens to match the conventions used by the 32 bit C compiler, but 64 bit conventions are different - there is no leading underscore.
Your `r` example works because there is no such specification of the linker name.
Delete the ALIAS:'_sfunc' attributes specification and things should work.
But I strongly recommend that you use the C-interoperability features of the Fortran 2003 standard instead of the !DEC$ ATTRIBUTES stuff.
