Fortran module wizard error
jvandeven
For some years I have used the Intel Fortran module wizard to generate the COM code necessary for communicating with Excel.  Recently I upgraded to VS2013, with the Intel Fortran compiler 15.0.0.108.  This upgrade appears to have introduced a conflict with my existing COM code.  I have tried generating new code using the Fortran module wizard, but now receive a range of error messages when I try to compile.  I am doing the following:
1) Selecting the Microsoft Excel 15.0 Object library from the COM components
2) I leave the "Generate code that uses Automation interfaces" unchecked (for efficiency)
3) Select the _Application, _Workbook, and _Worksheet members
4) I leave the "Generate DLLEXPORT statements" unchecked (I use this module internally)
5) press the finish button.
Code is then generated.  When I try to compile, I receive the following error messages:
Error    1     error #6401: The attributes of this name conflict with those made accessible by a USE statement.   [WORD]    C:\MyFiles\MODEL_LAB\FORTRAN\EXCEL\EXCEL.f90    534
Error    2     error #6445: A dummy argument is required in this context.   [WORD]    C:\MyFiles\MODEL_LAB\FORTRAN\EXCEL\EXCEL.f90    534
Error    3     error #6445: A dummy argument is required in this context.   [WORD]    C:\MyFiles\MODEL_LAB\FORTRAN\EXCEL\EXCEL.f90    535
Error    4     error #6717: This name has not been given an explicit type.   [WORD]    C:\MyFiles\MODEL_LAB\FORTRAN\EXCEL\EXCEL.f90    530
Error    5     error #6075: The data type of the actual argument does not match the definition.   [$BSTR_WORD]    C:\MyFiles\MODEL_LAB\FORTRAN\EXCEL\EXCEL.f90    11255
Error    6    Compilation Aborted (code 1)    C:\MyFiles\MODEL_LAB\FORTRAN\EXCEL\EXCEL.f90    1
I attach the F90 file that is generated by the wizard for information.  Any help resolving this issue is greatly appreciated.
Justin
It is still reproducible - still investigating.
