You might have some success by modifying your make file to use "echo" to construct the
compiled = "xxx"
statement into a Fortran include file. As an example into "when.fi" and then use the Fortran include statement to include the file in the appropriate line of your program.
Jim Dempsey
Hi Tim, The build is using Intel MPI, just redirecting the mpif90 wrapper to ifort. Some further environment info: -bash-4.2$ env ... MKLROOT=/curc/sw/intel/17.4/mkl AR=xiar INTEL_LICENSE_FILE=/curc/sw/intel/17.4/licenses/USE_SERVER.lic CURC_INTEL_BIN=/curc/sw/intel/17.4/bin I_MPI_FABRICS=shm:tmi I_MPI_EXTRA_FILESYSTEM=1 HISTSIZE=1000 CURC_INTEL_INC=/curc/sw/intel/17.4/include MKL_MIC_ARCH=mic TMI_CONFIG=/curc/sw/intel/17.4/impi/2017.3.196/etc64/tmi.conf CURC_INTEL_ROOT=/curc/sw/intel/17.4 HAS_BLAS=yes USE_MPIF=y MIC_LD_LIBRARY_PATH=/curc/sw/intel/17.4/mkl/lib/mic:/curc/sw/intel/17.4/compilers_and_libraries_2017.4.196/linux/mpirt/lib/ia32_lin:/curc/sw/intel/17.4/compilers_and_libraries_2017.4.196/linux/compiler/lib/mic NWCHEM_TOP=/projects/chch5350/Packages/nwchem-6.6 LD_LIBRARY_PATH=/curc/sw/intel/17.4/compiler/lib/intel64:/curc/sw/intel/17.4/mkl/lib/intel64:/curc/sw/intel/17.4/impi/2017.3.196/lib64:/curc/sw/intel/17.4/compilers_and_libraries_2017.4.196/linux/compiler/lib/intel64:/curc/sw/gcc/5.4.0/lib64:/projects/chch5350/lib:: MKL_TARGET_ARCH=intel64 MIC_LIBRARY_PATH=/curc/sw/intel/17.4/compilers_and_libraries_2017.4.196/linux/mpirt/lib/ia32_lin:/curc/sw/intel/17.4/compilers_and_libraries_2017.4.196/linux/compiler/lib/mic USE_MPI=y CXXFLAGS=-xCORE-AVX2 CURC_MKL_LIB=/curc/sw/intel/17.4/mkl/lib/intel64 CURC_IMPI_LIB=/curc/sw/intel/17.4/impi/2017.3.196/lib64 CURC_FAMILY_MPI=impi PATH=/curc/sw/intel/17.4/impi/2017.3.196/bin64:/curc/sw/intel/17.4/compilers_and_libraries_2017.4.196/linux/bin/intel64:/curc/sw/gcc/5.4.0/bin:/projects/chch5350/bin:/usr/lpp/mmfs/bin:/usr/local/bin:/usr/bin:/usr/local/sbin:/usr/sbin:/opt/dell/srvadmin/bin CURC_MKL_BIN=/curc/sw/intel/17.4/mkl/bin I_MPI_EXTRA_FILESYSTEM_LIST=gpfs NWCHEM_MODULES=qm LD=xild CURC_INTEL_LIB=/curc/sw/intel/17.4/lib ARMCI_NETWORK=MPI-PR CURC_MKL_INC=/curc/sw/intel/17.4/mkl/include PWD=/home/chch5350/Projects/Packages/nwchem-6.6/src LOADEDMODULES=intel/17.4:impi/17.3:mkl/17.3 I_MPI_F90=ifort I_MPI_CC=icc USE_OPENMP=T MKL_LP64_ILP64=lp64 CXX=mpicxx I_MPI_HYDRA_PMI_CONNECT=alltoall I_MPI_CXX=icpc CFLAGS=-xCORE-AVX2 FC=mpif90 I_MPI_FC=ifort CURC_IMPI_ROOT=/curc/sw/intel/17.4/impi/2017.3.196 CURC_MKL_ROOT=/curc/sw/intel/17.4/mkl LARGE_FILES=TRUE CURC_FAMILY_COMPILER=intel BLASOPT=-mkl LMOD_FAMILY_COMPILER=intel LMOD_FULL_SETTARG_SUPPORT=no CC=mpicc ARMCI_DEFAULT_SHMMAX=4196 USE_MPIF4=y NWCHEM_TARGET=LINUX64 LMOD_FAMILY_MPI=impi I_MPI_ROOT=/curc/sw/intel/17.4/impi/2017.3.196 Hi Jim, Thanks for the suggestion. However, I would not venture into the wilds of the NWChem source code/build system without an intrepid guide... - Chris
SOLVED, just needed to modify ( "' ) and ( '" ) nested quotes in the makefile to ( \" ), and build works fine.
