Fortran source pretty printer/refactoring tool
rase
When I switched to IVF/F90/F95 many years ago I used the plusFORT tool from Polyhedron to modernize the hundreds of source files in my Fortran projects saving me a lot of time and effort.Today I tried to use plusFORT again, but the program told me that my license is no longer valid. I wonder if there is free pretty printer/refactoring tool for Fortran available which might include support for the more recent standards. Any suggestions?
Steven_L_Intel1
Have you tried contacting Polyhedron about your license? I find them quite responsive overall.
TimP
I doubt there is much along this line which is both supported and free.
Mike Metcalf's convert.f90 seems one of the better choices for including indentation.
I've modified ratfor to output much prettier than standard code, with indentation.  I wrote a lex processor so that most mixtures of f66 and f95 can be fed through struct and ratfor.
mecej4
PlusFort appears to be still available free for academic/educational use -- I don't know if you qualify.
rase
mecej4, plusFort is not avaible free of charge for educational use. The licence cost is too high compared to the frequency I will use it. I found a free tool (f90ppr), but it seems to be restricted to f90 format and is not easy to operate. Well, I think I will restructure the sources without software support, as I used to do it in ancient times.
Steven_L_Intel1
rase
Steve, thanks a lot for your advice. I contacted Polyhedron, they sent me a new license file rightaway (free of charge), and plusFORT is back to normal operation.
