Fortran
DAVLIS
I have Visual Studio 2019 installed and Parallel Studio XE 2020 Update 2.
I am unable to work out how to access/ find Fortran
I have read some of "doctor Fortran's" previous posts.
There are no "project types shown "with a little F in the upper right corner of the logo":
Nor can I see Fortran drop down etc.
Do you have any suggestions?  Thanks!
andrew_4619
In VS in the "about" menu option  do you see "Intel Fortran Compiler xxxx" listed?
Also do you see Microsoft Visual C++ listed as that is a prerequisite for the Fortran integration to install.
Steve_Lionel
Make sure you have followed the steps in this FAQ article: How do I install Microsoft Visual Studio 2019 for use with Intel Compilers?
Then do a Change/Modify on Intel Parallel Studio XE.
DAVLIS
Guys (and Gals),
Thank you, finally got it working.
I uninstalled/ Re-Installed Microsoft Visual Studio Community 2019 & Intel Parallel Studio XE 2020 Update 2
That did the trick.  (For some reason the Change/ Modify option did not work.)
Very much Appreciated!
andrew_4619
Yes that is often the way that works. VS is a fickle beast to work with, Standing on one whilst juggling swords whilst singing the Allegri Miserere mei also sometimes helps.
